Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
Front Sway Bar Bushing on 5th Gen: How-To...
Old Feb 27, 2005 | 08:11 PM
PoLo's Avatar
2-Wheelin it...
Hey Auto-Xers,
the 5th gen forum is lame and people find more importance in LED tails and fog bulbs. i think you guys might enjoy this more. it's obviously not the biggest add-on, but it's something for those who are slowly upgrading their bushings.
the link is to the install for the energy suspension front sway bar bushing set.
in fact, if you go higher up in my directory, you should see motor mount and subframe pictures.
link is: http://polo.lxanyc.com/2002MaximaSE/.../FrontSwayBar/
Old Feb 28, 2005 | 12:50 PM
black02's Avatar
ES FSB bushings install
Hey PoLo, thanks for yet another great install how-to. Your stuff is really useful.
Old Mar 1, 2005 | 05:59 PM
irish44j's Avatar
retired moderator
Marco, you know we're not all lame....did you ask ES if they needed a FSB bushing tester for the early 5th gens with the smaller FSB?
because you know I'd rather have these than any LED tails
Old Mar 5, 2006 | 01:21 PM
2002 Maxima SE's Avatar
Hey Polo,
Great write up, something I plan on doing. What's the diff between the 23mm and 22mm? What is stock?
Can you tell a big difference?
Old Mar 5, 2006 | 01:25 PM
irish44j's Avatar
retired moderator
Originally Posted by 2002 Maxima SE
Hey Polo,
22mm is for GXE/GLE models, 23mm is for SE models, which have a slightly thicker FSB. The difference is not night and day, but it does tighten up the front end a little bit. It's a cheap and easy mod, and that makes it worthwhile. Every little bit counts.
Old Mar 5, 2006 | 01:32 PM
Thanks for the quick response!
Old Mar 5, 2006 | 01:44 PM
PoLo's Avatar
2-Wheelin it...
the only reason i can't say whether i can tell a difference or not is because i've had various susp. setups, from coilovers slammed to springs, and then motor mounts, then subframe, and then FSB. as soon as weather permits, i'll be doing the trailing arm and control arm bushings.
essentially, the FSB should hold the wheels firmer to the ground when in turns, especially when you hit bumps. i know that before, when i used to take exits off expressways, and i hit a bump, the car would skip around. i dont' anymore, but that may be a combination of springs AND the FSB Bushings.
i promised myself that this season i'd install the trailing and control arm. it will be done, write-up and all.
Old Mar 7, 2006 | 01:33 PM
Deckdout2's Avatar
Play with my balls
Thanks polo.....I actually need this badly. You're right, it is more useful here!
Old Mar 7, 2006 | 03:37 PM
DrKlop's Avatar
Driving is the next best thing
PoLo,
seems like the link is not working, could you repost the writeup, please...
Old Mar 7, 2006 | 03:49 PM
DrKlop's Avatar
Originally Posted by DrKlop
PoLo,
never mind, I found it
Old Mar 7, 2006 | 06:37 PM
PoLo's Avatar
2-Wheelin it...
yeah, that polo.lxanyc.com link was a generic link since my friend owns lxanyc.com. i went ahead and purchased digitalpolo.com, so most links floating around should be replaced with that if you want it to work.
Old Apr 5, 2006 | 04:49 PM
Deckdout2's Avatar
Play with my balls
Where do you find these sway bar bushings for the 5.5 gen? (poly urethane) How much can I get them for?
Old Apr 5, 2006 | 05:04 PM
Puppetmaster's Avatar
Paramy, you can get em from here:
http://www.suspension.com/nissancars.htm
Or even from Matt Blehm, SCO, or Cattman.
Old Apr 5, 2006 | 07:18 PM
DrKlop's Avatar
don't order them from SCO, they don't have them in stock and would back order them only once you placed your order.
I ordered mine in February ... still haven't received them...
Old May 7, 2006 | 09:33 AM
Have you gotten yours yet DrKlop?
Old May 7, 2006 | 12:38 PM
Deckdout2's Avatar
Play with my balls
Thanks for letting me know. I'm about to get these from the link Joel put up. Yeah, did you get yours from SCO yet?
Old May 7, 2006 | 01:42 PM
DrKlop's Avatar
Ya, I got them, but only on May 3rd. The order was placed on February 28th.
So if you guys will be ordering anything from them, make sure that they actually have the product.
Old May 8, 2006 | 03:35 PM
Deckdout2's Avatar
Play with my balls
Just bought mine. Hopefully I'll get them by the end of this week.
Old May 9, 2006 | 08:55 AM
DUKEE's Avatar
why dont they bundle all the bushings together for a better price ;( i want to grab all of them!
Old Jun 8, 2006 | 05:44 AM
flashlightlens's Avatar
Where? The redirect doesn't seem to work.
Old Jun 8, 2006 | 05:46 AM
PoLo's Avatar
2-Wheelin it...
if you change polo.lxanyc.com to digitalpolo.com, you'll be fine....
i changed to a domained site....here:
http://www.digitalpolo.com/2002Maxim.../FrontSwayBar/
Old Jun 8, 2006 | 11:07 PM
DrKlop's Avatar
What are the torque specs for the bolts that hold FSB bushings?
Old Jul 22, 2006 | 12:10 PM
^^^ My haynes manual said 36 to 42 ft pds.
Did the Maxima SE already come with polyurethane bushings? I assumed they were rubber, but when I took my old ones off, they look/feel exactly like the ones from ES. The ES ones did sit a bit higher (1/4 inch) when I went to put the hat back on after setting them.
If the old were polyurethane too, what is the advantage of the ES bushings?
MAXSE5SPD
Sep 17, 2022 04:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
Lowered_a33
Sep 1, 2015 07:49 PM
