Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
Auto-x tire advice
Old Mar 21, 2005 | 04:41 PM
irish44j's Avatar
retired moderator
Auto-x tire advice
I've already gotten some input from Matt B., but wanted to find out what everyone else is runnig for tires.
rims: 17x7.5/17x8
track type: lower speed auto-x for this season probably <50-60mph topout
not worried about high-speed auto-x or road course.
price: cheap as possible.....probably will get about 5-6 days tops this summer, so can't justify and expensive comp tire.....
EXPERTS: suggestions on tire size and tire brand????
Old Mar 21, 2005 | 07:23 PM
z32drifter's Avatar
I'm running "R" compounds this year..... however I had very good luck with Kumho MXs it would be a toss up between those and the Falken RT-615 ... tire size depends on the rim..... try and keep the rim on the upper limit of the tire size .... ie don't stuff a big tire on a small rim.... performance won't be as good as the proper size tire.... 7.5 8.0 I would look at 225s or 235s ...... I'm running a 17x9 with a 255
Old Mar 21, 2005 | 08:59 PM
BEJAY1's Avatar
Conecarver
Somewhat depends on your class limits but how bout
STS
Good - 16x7.5 300ZX rims with 225/50 Kumho 712 rubber < $500
Good - your rims with 225/45 Falken RT-615 rubber $550ish
Better - 16x7.5 300ZX rims with 225/45 Hankook R-S2 rubber $550ish
STX
Good - your rims with Hankook R-S2 245/45 < $500
Very Good - your rims with Ecsta MX 245/40 about $550ish
Better - 16x8 300ZX rims (or similar) with Hankook R-S2 245/45 $650 ish
Hell of a deal on these I just found
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7962499292
Old Mar 22, 2005 | 02:32 PM
irish44j's Avatar
retired moderator
STS
STX
For the time being I'm doing local (capital racing club) auto-x, not SCCA....since I am totally screwed for SCCA because of my stage II LTB.
As to 16's...can't happen - I have the 6th gen rotors/calipers on my max, which don't even clear my stock 17's (why I'm using the infiniti rims)
Old Mar 22, 2005 | 06:14 PM
Matt93SE's Avatar
STFU n00b!
I recommend the same as what Bejay said, but change the sizes to fit your wheels.
Old Mar 22, 2005 | 07:15 PM
irish44j's Avatar
retired moderator
thanks guys....just did some research on the Hankook R-S2s and they seem to be getting the good word. Helps that 225/45/17 are only $110 each on edgeracing.com (see if I can find them cheaper locally first, of course).....
Dunno if any of you has used them (?) or are speaking from reviews/secondhand info. If not, I will be the test donkey I suppose
planning to order them tomorrow...first use will be the 9th....
Old Mar 23, 2005 | 05:48 AM
BEJAY1's Avatar
Conecarver
Hope you can get em. Word has it that some suppliers and Hankook are already low on stock after initial orders. 4/9 is the first date in Atlanta and Chicago for feedback on these too from what I'm reading. Good luck.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Garrettz459
Sep 28, 2015 02:50 PM
