Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
keeping brakes cool
Old Jul 17, 2005 | 03:38 PM
SkinnyMax's Avatar
maxima no more
keeping brakes cool
since I can't afford a BBK I need to figure out a way to keep the brakes cooler. Idealy I would run some brake ducts, but in order to get even cooling the hose needs to blow through the center of the rotor out through the veins. Does anyone know if it is possible to remove the dust shield on a 4th gen? It appears that it is pressed into place but I didn't get a good look since it started to rain.
Old Jul 18, 2005 | 05:27 AM
gdmaxse's Avatar
i wouldnt remove it, id cut a hole in it and use it to hold the ducting in place with an endclamp or something
Old Jul 18, 2005 | 06:39 AM
Matt93SE's Avatar
STFU n00b!
yeah, what he said.
chopping a hole in it will be difficult, but can be done with some tin snips and patience. if you're careful, leave a few tabs on it that you can bend back and use a hose clamp to hold the ducting onto the spindle with. should work fairly well.
but why do you need to do this anyway? even on road course use with stock brakes and good pads (hawk HP+ or so), you shouldn' have problems with overheating them until you're REALLY beating on the car.
Old Jul 18, 2005 | 07:18 AM
97SEdriver's Avatar
this place is dead
Originally Posted by Matt93SE
yeah, what he said.
I agree,
I didn't even have Hawk pads, and the 4 20min sessions at Pocono didn't hurt my brakes at all, no fade, even when trailbraking into the infield at 90.
See, there you go, (sorry if some of you have seen the picture before, I have others but this is my favorite one.)
Old Jul 18, 2005 | 02:20 PM
SkinnyMax's Avatar
maxima no more
last event I was running GreenStuff pads (I know not the greatest for the track) and they were noticably fading, I am going to be running HP+'s next so hopefully that will cure the problem. But would still be nice to keep them at a lower temp and run a slightly cheaper pad.
Old Jul 18, 2005 | 07:07 PM
aznsap's Avatar
i took my dust shields off. i just used a dremel to cut a slit in it and banged it off w/ hammer.
Old Jul 18, 2005 | 07:52 PM
Larrio's Avatar
The Definitive AE Master
i think your stock brakes should hold up fine unless your either late braking or running at a track thats extremely hard on the brakes, like sears pointe
Old Jul 19, 2005 | 10:40 AM
Matt93SE's Avatar
STFU n00b!
yeah, greenstuff are crap when you drive that hard.. stick the HP+ on and you'll see a world of difference.
when your'e done at the track, stickt he greenstuffs back on and drive home.
Old Jul 19, 2005 | 02:06 PM
SkinnyMax's Avatar
maxima no more
Thats what I wanted to hear, I'm running out of time if I needed to make any sort of ducting. Gotta keep as much speed into the corner so I don't have to lift on the straights when the miata's catch me in the turns
Old Jul 19, 2005 | 06:38 PM
97SEdriver's Avatar
this place is dead
I've been there, look at the cars coming up from behind me.
unless their turbo'ed, you can usually kill them in the straights.
imported_Nismo_max
Sep 20, 2015 08:19 AM
pears
Sep 18, 2015 05:25 AM
