Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
Hankook Ventus RS2 Z212 shaved pics - FYI
Old Feb 1, 2006 | 01:55 PM
irish44j's Avatar
retired moderator
Since you guys are always interested in tread patterns and whatnot....just thought I'd post some pics of the Z212s shaved to 4/32". Of note this size (245/45/17) has a 99 load rating and the sidewalls are noticeably stiffer than the 225s still sitting in my basement from last season - still not the stiffest, but "stiffer"...I still think Hankook would do well to make the treadblocks a little wider (for more "rubber on the road") but for $114 each (+60 for shaving all 4) the 'kooks still can't be beaten for value.
My UPS driver opined that he was thinking about keeping them for himself and using them on his M3 Hopefully I'll have them mounted on friday and try to put a heat cycle on them one day this weekend before they go back into the basement
Old Feb 1, 2006 | 05:05 PM
97SEdriver's Avatar
this place is dead
You ever shave your tires before? Since you know how serious I am about equipment I always would just burn off the tread, I can't say I ever noticed a difference until they were worn enough not to pass inspection in PA, I saved those tires though.
Old Feb 1, 2006 | 05:23 PM
vsamoylov
interesting irish. quick question about the heat cycle. i know tirerack offers it and they use a machine but how will you do it?
Old Feb 1, 2006 | 05:42 PM
irish44j's Avatar
retired moderator
heat cycling the tires is really just a matter of giving them some hard use for a short time period (a day or two) and then taking them off the car and putting them back into the garage....the theory behind it is to help the rubber maintain its elasticity, etc..
I'm describing it POORLY here...not saying it right...
Old Feb 1, 2006 | 05:48 PM
97SEdriver's Avatar
this place is dead
I'll say, don't you have a technical backround?
Old Feb 1, 2006 | 06:22 PM
irish44j's Avatar
retired moderator
it's been a long day...
I'll let tire rack do the talking for me:
The first time a competition tire is used is the most important. During that run, its tread compound is stretched, some of the weaker bonds between the rubber molecules will be broken (which generates some of the heat). If the tires are initially run too hard or too long, some of the stronger bonds will also be broken which will reduces the tire's grip and wear qualities. Running new tires through an easy heat cycle first, and allowing them to relax allows the rubber bonds to relink in a more uniform manner than they were originally manufactured. It actually makes them more consistent in strength and more resistant to losing their strength the next time they are used. An important heat cycling step is that after being brought up to temperature, the tires require a minimum of 24 to 48 hours to relax and reform the bonds between their rubber molecules
Old Feb 1, 2006 | 06:24 PM
97SEdriver's Avatar
this place is dead
Well that was more easily understood anyway.
Old Feb 1, 2006 | 08:16 PM
BEJAY1's Avatar
Conecarver
Congrats. Interesting about the stiffer statement. Is it the exact same sidewall plies construction between the 225 and 245?
Old Feb 2, 2006 | 06:20 PM
irish44j's Avatar
retired moderator
visually, it appears so, but pushing on both at the same time, the 245s are definitely a bit stiffer....not night and day, but noticeable.
Maybe the sidewalls are heavier ply to achieve a higher load rating?
Old Feb 4, 2006 | 08:36 PM
BRINKLEY's Avatar
this is done in nascar frequently, a car that has been in a wreck several laps down will run some tires for a teammate to warm them up and put a good heat cycle through it, this also scuffs them which seems to help grip on the track...... just thought I'd share that. lol
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
