Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
What gets wax off trim?
Old Jul 20, 2003 | 12:14 AM
lunchbox's Avatar
I got wax on the black trim around the windshield, and I can't get it off. What would be the best way to go about doing this?
Kevin.
Old Jul 20, 2003 | 02:22 PM
CanadianMoFo's Avatar
Mothers Back To Black. Spend some quality time using a toothbrush to scrub it off.
Personally I use green painters tape on areas like that when I'm waxing. I've made the same mistake before and found that a little prep time is worth it.
CM.
Old Jul 20, 2003 | 02:25 PM
lunchbox's Avatar
Thats kind of what I was thinking. Thanks man.
Kevin.
Old Jul 20, 2003 | 02:45 PM
Sqard's Avatar
peanut oil or peanut butter for the stubborn stuff
Old Jul 20, 2003 | 05:38 PM
Bman's Avatar
Back to Black may or may not remove it sometimes I've heard and just cover it up. Also it might run off once it gets wet. Other than peanut butter, other things you can try are a white vinyl eraser, and a bug and tar remover.
What wax was this anyway that stained?
One tip I have heard to prevent trim staining is to coat the trim with a rubber/vinyl protectant before you wax. I haven't tried this myself (most of my waxes don't stain anyway), but it's supposed to work.
Old Jul 20, 2003 | 06:15 PM
quickwaxsix's Avatar
a toothbrush works fine for me, but back to black couldn't hert
Old Jul 21, 2003 | 12:20 PM
endus's Avatar
An atavistic endeavor...
Back to black works although I've heard that Peanut Butter works CRAZY. Haven't tried it yet but I will be...
Old Jul 21, 2003 | 12:27 PM
lunchbox's Avatar
Meguiars Mirror Glaze Swirl Remover 2.0
Old Jul 21, 2003 | 01:20 PM
Bman's Avatar
Umm.... Meguiar's #9 swirl remover isn't a wax... no wonder you got staining. #9 is a polish, and when using such products you should either take the time to mask off the trim (not as bad as it sounds) or try the protectant trick. Older, rough trim that is worn is even worse for staining.
I hope after #9 swirl remover you followed up with a pure glaze (like #7) and then used an actual wax... What have you done so far?
Old Jul 21, 2003 | 02:19 PM
I have used peanut butter on plexiglass to take off tape residue without scratching the plexi. Its a pretty good cleaner, and cheap too. Couldn't hurt to use it too.
Basically any sort of cleaner + toothbrush will work to get the wax off your trim pieces.
CM.
REDinLV
Aug 15, 2024 12:30 AM
BobTX10
Oct 7, 2015 08:43 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Redfox
Sep 28, 2015 10:41 AM
