Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
HELP! my neice puked in the rear seats!!
Old Dec 28, 2003 | 09:43 PM
minsbang's Avatar
my 7 year old neice puked in my car and i took out the rear seats (black leather) and i removed all the ccrraapp. What do i use for my black leather to clean it and to remove the odor?
Old Dec 29, 2003 | 09:05 AM
ghostrider17's Avatar
Was it your Driving???
My daughter did the same in my wife's car (leather) a few years back as well....! The good thing, is that you DID have leather.
....hurling on cloth is BAD!
You did the most important thing - which is to clean it immediately.
Stomach acids are not exactly good for leather.
ALWAYS use a MILD cleaner on leather - or SIMPLY just clean water.
Heavy detergents or cleaners will DRY-OUT leather's natural oils, and lead to pre-mature cracking. (simple green = BAD idea!)
Aside from cleaning the area THOROUGHLY, I'm a big believer in LEXOL leather products. LEXOL can be purchased at almost ANY automotive store, WAL-MART, PEP-BOYS, etc.
I would suggest using the ORANGE-bottled CLEANER VERY LIBERALLY on the leather to remove any residual debris and acid.
~I use a perforated, nylon-covered sponge that is primarily sold as a BUG-REMOVER to scrub the seats WITH the cleaner. (walmart~$2.99)
This works well, as it will not scratch the leather, while being mildly abrasive.
~Use a WARM bucket of water, and dampen your sponge-scrubber.
~Apply the cleaner to the sponge, and work into the leather.
~Do not be affraid to work this mixture into a lather over the entire seating area, as it will serve to break-up and loosen any ground-in matter that is still on the leather.
~Make SURE to get in-between the cracks and seams --SOAKING the seats should aide in this operation. Don't be affraid to get the seat WET. It will not damage the leather. LEXOL is Ph-balanced.
~Rinse your sponge in the clean water frequently, just as with any other cleaning medium.
~Repeat as needed, let dry into a haze, and then rinse residue with clean water and rag. Allow to dry. (seats should dry by the time you work from the front to back seats, or vice-versa)
Second Step--
~LIBERALLY apply the BROWN-bottled CONDITIONER with a non-colored cloth or rag. (some colored towels WILL bleed into the leather)
~Let-Dry into a hazy film -- Repeat.
Let dry, and then buff with a clean dry towel. DO NOT RINSE THIS STEP.
Voila.
I regularly apply the Conditioner to keep my leather soft and supple.
The Cleaner is reserved for accidents and once a year cleansing.
Not sure about removing the smell, especially if it's in the carpet -- but the cleaner should get rid of any offending odor residing in the leather seat.
Lexol has a VERY mild scent, that doens't really smell like anything you'd classify as "deoderizer". Hard to explain - but you'll understand. I've come to enjoy the smell -- but, that's just me.
I have black leather as well, by the way.
good luck!
gr
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
doctorpullit
Sep 10, 2015 06:33 PM
ef9
Sep 5, 2015 11:18 PM
