Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
meguiar #7
Old Jan 5, 2004 | 07:26 PM
outsider's Avatar
meguiar #7
is meguiar #7 a glaze or a polish?
and what is the difference between the two?
Old Jan 5, 2004 | 11:04 PM
Bman's Avatar
It depends what you define as a "polish". The short answer is that it's a non-abrasive glaze that will help shine up the paint and hide minor flaws.
A "polish", as most people think of that word, is usually abrasive, but the word has been horribly misused and used to describe all sorts of products. It really depends on the manufacturer.
Old Jan 6, 2004 | 09:13 AM
outsider's Avatar
so i can use the #7 and follow it up with a wax and ill be fine?
but will i accomplish a nice shine if i do this step?
Old Jan 6, 2004 | 09:51 AM
MaxSE03's Avatar
That will work just fine. However, you want to make sure the paint is clean prior to the #7 since it has no cleaning abilities. If it is, go with the polish and then a coat of wax. If not, use Meguiar's Medallion Premium Paint Cleaner, then the #7, and follow with a wax of your choice. Here is a pic after a coat of #7 and a top coat of Pinnacle Souveran, Pic.
Old Jan 6, 2004 | 10:32 PM
Bman's Avatar
Ditto. "Cleaners" by the way, are what people normally think a polish should be. Meguiar's is particularly fond of calling various grades of abrasive products "cleaners". They're not cleaners like soap, so don't think of them doing the same thing, they're abrasives that range from mild to aggressive. The abrasive (usually mild - the Step 1 pre-wax cleaner stuff is a good example) combined with the solvents in them allow subsequent products to adhere and work better.
Old Jan 10, 2004 | 11:00 AM
JonnyCum Lately's Avatar
One last comment on using #7. It hard to remove, so don't try removing it in one pass. Instead, apply it to the entire car and then go back and remove it using several passes. #7 contains a lot of polishing oil, so each time you wipe down a panel you end up reliqufying it. Use a terry towel on the first pass, and then finish it up with a microfiber towel.
I learned this from the autopia.org forum. A Meguiars' tech guy named Mike Phillips provides an excellent explanation on how to remove #7.
I used #7 on my dark blue Max last April. It creates a wet look and fills in lots of the light scratches.
LouE37
21
Apr 28, 2003 04:14 AM
BlancMax
Mar 26, 2002 06:15 PM
luvmymax
Oct 22, 2001 09:44 AM
Johnson
Nov 25, 2000 06:17 AM
