Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Cleaning the cleaning stuff
Old Mar 15, 2004 | 06:16 PM
96GreenMax's Avatar
So I just finished washing, polishing, and waxing my car, it looks great, but now I have a lot of dirty rags. What is the best way to clean all of this stuff. It seems that getting this stuff clean is really important to keep from scratching the paint. well thanks for reading
Old Mar 15, 2004 | 11:21 PM
Stealth Max's Avatar
Just use regular detergent in a washing machine to clean the 100% cotton towels. Don't use fabric softeners on the towels. You will be good to go.
Old Mar 16, 2004 | 03:25 PM
Bluesbrekr's Avatar
Doctorate in Detailing
I would suggest washing any micro fiber seperately. They will pick up lint and stuff from cotton towels and rags. Dreft is a good choice for the detergent.
I usually let the microfiber stuff line dry and I'll put the cotton stuff in the dryer. And as StealthMax said, don't use any type of fabric softener or sheets.
Old Mar 16, 2004 | 09:35 PM
Bman's Avatar
Also, try to wash them soon after use so that the products sitting in it don't have as much chance to set in.
If the cloths are really loaded with product, consider pre-soaking them in some detergent in a bucket first, and then rinsing them out before throwing them in the washer. If you don't, sometimes you will leave a waxy, white ring around the waterline in the washer and your mother/spouse/significant other will KILL you.
PS: I really hope you aren't actually using "rags".... scratch city right there if you're using cheap toweling.
Old Mar 18, 2004 | 01:03 AM
Dave Holmes's Avatar
What Bman said.
You may also want to consider using a liquid only detergent. Powders may not dissolve completely, and therefore could stay in the towel. This would cause scratches/marring.
MF should be washed totally seperate from any others. If you don't, it could take you hours to pluck the lint out of them with tweezers afterwards.
A double rinse is a good thing. Makes sure all the detergent is out. Another good way of doing this is to add about 1/4 cup of distilled white vinegar to the final rinse. This helps break the bond between the detergent and fabric, allowing the detergent to be rinsed away. This trick is actually probably the first fabric softener. Works really well.
Unless you worry about fading of your towels, use the hottest water you can for the wash. Household hot water is not hot enough to harm any of the cotton or MF. And hot water cleans so much more effectively.
Dave
Old Mar 22, 2004 | 05:42 PM
96GreenMax's Avatar
Thanks for the help. I am not using rags, MF all the way, but doesn't matter now cause I jacked up my fender and have to get it repainted and I might just get the whole car done if I can get enough money together
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
