Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Help - Pine Sap Removal!
Old Jun 21, 2004 | 05:51 AM
Puppetmaster's Avatar
Hey everyone... I hope this isn't too retarded of a question... but I got a good amount of pine sap on my hood (I kno, dumb@$$ for not noticing the pine trees when I parked my car) and was wondering if anyone had any cleaning recommendations. With my old VW I could use Goof Off, but I'm not sure how the 5th Gen's paintwork would react to that (since I heard we have pretty "weak" paint on our cars)... lemme know if anyone has experience with this. The sooner I get that sap off the better! Thanks!
Old Jun 21, 2004 | 06:12 AM
Zero Deuce SE's Avatar
You could use some 3M adhesive remover or the bug, tar and sap remover that Stoner sells.
Old Jun 21, 2004 | 06:15 AM
2k3TitaniumSe's Avatar
Wrong forum section. Try detailing forum for better answers.
Old Jun 21, 2004 | 06:16 AM
http://www.tarminator.com/
Old Jun 21, 2004 | 06:23 AM
Thanks to both of ya.... I'll post in the Detailing section as well...
Old Jun 21, 2004 | 09:37 AM
frankieduxAE's Avatar
rubbing alcohol works for me.
Old Jun 22, 2004 | 04:14 AM
Thanks... I've only tried a Turtlewax Bug and Tar Remover and it doesn't get everything off.... I actually tried using a little Goof Off on a small spot and it works well but I'm not sure how much of that I wanna use on the car... I immediately washed out the area after using it...
Old Jun 22, 2004 | 04:16 AM
Hmm... sounds like that's worth a try too.... I wonder which is more potent... rubbing alc or Goof Off (still worried about the thin paint job on these 5 Gens)
Old Jun 23, 2004 | 02:09 PM
PrinzII's Avatar
OG and counting...
The alcohol is strong. I'd suggest 3M's Tar and adhesive remover.
Old Jun 24, 2004 | 12:33 PM
MaxSE03's Avatar
By a little bottle of concentrated windshield washer fluid from any automotive store(not the big bottle, the little bottle that you have to mix with water). It will only cost you about a $1.00 and with take the sap off with ease, guaranteed! Just put it full strength onto a rag and wipe the sap off.
Old Jun 24, 2004 | 06:40 PM
CanadianMoFo's Avatar
WD40 sprayed on helps soften tar and sap up.
Old Jun 28, 2004 | 04:11 AM
Thanks for all the tips. I ended up using Goof Off and got all the sap off the hood.... then I washed everything thoroughly to make sure there was nothing still lingering on the paint (only to get shat on the hood by some damn birds). Anyways, next time I might try the windshield washer fluid way, that sounds the best.
Btw, WD40 didn't work last I tried... I think that only works if you get the sap almost immediately after it hits the car.
Old Jun 28, 2004 | 04:14 AM
One more thing, MaxSE03, good pics on your website.... those pics helped me decide to get my GReddy Evo when I saw how it looked on your car... thanks!
Old Jun 28, 2004 | 10:00 AM
dafowl1's Avatar
I hope you waxed it after the goof off I would that stuff would strip the wax off
Old Jun 28, 2004 | 10:52 PM
mjg's Avatar
mjg
dawn works real well, though dilluted with car wash. Work the area, do not rub too hard, it will loosen it up. If you rub very hard, it will create very dull nasty swirls. After this, your car will absolutely require heavy duty polishing. I had this happen to me atleast twice, and it was really, really bad. I had my entire car covered. Also, the longer it stays on, the more it will eat at your paint, so you need to get sap off immediatly.
After a few days, it leaves a small area where the paint rises up, and it looks like crap!
Lesson: Never park near a tree, under a tree, or in the general area of a tree during a windy day.
Glad you fixed it.
Old Jul 1, 2004 | 01:22 PM
MaxSE03's Avatar
Glad it helped you out! Definitely try the windshield washer fluid next time. It's a trick i learned about 4 years ago and it works better than anything else you can buy.
Old Jul 4, 2004 | 04:09 AM
PrinzII's Avatar
OG and counting...
If all else fails, use mineral spirits to soften and remove the pine sap.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
