Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
How should i apply touch-up paint?
Old Jun 21, 2004 | 10:34 AM
quickwaxsix's Avatar
I have a huge key mark on the side of my car, and I'd like to use the touch-up paint i bought from the dealership to fix it. What do i need to do to apply it? Is there any sanding involved? I would really apreciate it if someone could give me some advice, or point me to a page or another thread that could help me out. Thanks.
Old Jun 21, 2004 | 09:42 PM
housecor's Avatar
Use a toothpick or butt end of a match to apply small amounts and light coats. Give www.langka.com a look to get rid of the blob.
Old Jun 22, 2004 | 01:25 AM
Nismo's Avatar
apply as in dotting the paint onto the surface or stroke it on?
Old Jun 22, 2004 | 01:27 PM
2k3TitaniumSe's Avatar
Just put it on and use langka. Works well.
Old Jun 22, 2004 | 09:57 PM
00MAXI's Avatar
http://www.courtesyparts.com/paint/p...ninstruct.html
Old Jun 23, 2004 | 11:21 AM
DonSupreme's Avatar
Does this langka thing really work as well as they say on their website? What are your opinions of its actual performance.
Old Jun 23, 2004 | 12:16 PM
2k1seae's Avatar
My experience with Langka is that it was difficult to build up a bump with the TU paint. If you don't have a bump, then the excess TU paint will come off and still leave the nick or scratch. It does work pretty well if you follow the instructions carefully. It seems to work only with dealer supplied TU paint. If you get TU from a body shop after a repair, this will not work effectively.
Old Jun 24, 2004 | 01:07 AM
Nismo's Avatar
What type of paint were you using? the pens or the bottle and brush? When I bought some at the dealer, it was a bottle with a paint brush on the cap and it was very easy to dab a blob of paint on the surface. Im very interested in this Langka stuff sometime as I have a pinto bean sized scratch on my door.
Old Jun 24, 2004 | 06:34 AM
2k1seae's Avatar
I used the bottle with the brush on it. When I applied it, it settled into the chip (didn't fill). I would have to apply several times to build it up. It works okay, but requires a lot of patience. I still haven't quite figured out how to drip the langka onto vertical surfaces. As long as you can build it up, it would probably work. I haven't tried it on any large chips or long scratches. Go to www.langka.com. The sight might answer some other questions.
Old Jun 25, 2004 | 05:36 PM
00MAXI's Avatar
Attn Pioneers
If anybody tried that Nissan paint pen let me know. I posted the link earlier in the thread because it looks like it doesn’t blob as the brush does.
Old Jun 26, 2004 | 09:21 PM
Nismo's Avatar
I tried a friends paint pen before and I didnt like it.
BTW I just ordered some Langka today- 2oz langka,clearcoat and brush, should be here in a week or so. Ill post what I think about it and also some before+after pix of a good size chip once I try it
Old Jun 30, 2004 | 05:33 AM
Grey00lustre's Avatar
Nismo, what kind of touch-up paint are u using along with langka? are u using nissan oem tu paint and if so does the color match?
Old Jun 30, 2004 | 06:27 AM
2k1seae's Avatar
I tried the paint pen and I didn't have much luck with it. I couldn't get the clear coat to apply very good. I believe the langka recommends the OEM touch up paint.
Old Jun 30, 2004 | 06:35 AM
2k1seae, i know langka recommends oem touch up paint...but my question is does the paint match?
Old Jul 1, 2004 | 05:46 PM
Nismo's Avatar
im in the middle of putting on my touchup paint so I can use Langka. Ill take a before and after pic of one of the chips to show you progress.
Old Jul 2, 2004 | 10:01 AM
2k1seae's Avatar
My car is black, so yes, mine matched great. I've read that some of the colors don't match very well. I think silver was worst, but could be mistaken.
Old Jul 2, 2004 | 10:17 PM
Nismo's Avatar
I just tried Langka and heres what I have to say.
Langka does work in taking the paint blob down level BUT- for my pebble beige metallic, it makes it dull and darker color and seems to remove the metallic flakes from the touchup paint, leaving it flat and darker in color(only affects touchup paint, doesnt harm factory paint), im shure this stuff works with other colors but for CG2, it doesnt seem to come out good color wise.
SO, I decided to make up my own touchup paint method that gave me better results. It involves masking off the paint surrounding the chip, just cut tiny strips of masking tape and tape it at the edges of the chip, bordering the chip, Next use your touchup paint brush and lightly apply a very thin and even coat of paint, let it dry for a minute, remove masking tape to inspect. Keep repeating the process of masking and painting until the touchup paint is level with the factory paint, this may take several coats of paint. The trick is to mask it perfecty at the edge of the paint so you dont overlap the factory paint and also light even coats so you minimize brush marks.
Old Jul 3, 2004 | 12:51 PM
Qmax03
the only color which is the hardest to match is the pearl white NOBODY could match that color 100% not even the dealer!! i got my kit painted 3 times already i got the touch up paint from the dealer and itss TOTALLY off . i hate my coloR !
Old Jul 3, 2004 | 08:12 PM
housecor's Avatar
Langka can darken the TU paint effect a bit from my experience on Sheer Silver in some situations. I think it just depends on the luck of the draw on the amount and placement of the metallic flecks in the paint. Be sure to shake the paint very well. I got excellent (near invisible unless very close) results with Langka on all my touchups except one that came out dark because I didn't shake the can well.
Old Jul 4, 2004 | 07:19 AM
CanadianMoFo's Avatar
Instead of using a toothpick to apply the paint to small stone chips, try going to an art supply store. You can get a fine fine fine tipped brush for a couple bucks that does an excellent job. I think the one I got was a '00' size. It really is much better than a tooth pick. You have to have the right tools for the job.
CM.
Old Jul 5, 2004 | 11:47 PM
Nismo's Avatar
Trust me I shook the shtt out of that bottle and even shook it a lot everytime I dip the brush in but I cant seem to keep the flakes from comming off
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
doctorpullit
Apr 23, 2017 05:35 AM
