Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Help! My Paint is Faint
Old Jul 30, 2004 | 09:35 PM
5spdMaxSEma's Avatar
My black 99 Maxima doesn't shine like it should. I spend so much time wash/polish/wax it, and it always comes out looking dull. It actually looks better dirty than clean. My friend was telling me that some detail shops can remove a small amount of my clear coat to make it look practically brand new. If there are such place that can do this for me please let me know of some in the Chicago land area. Thanks in advance.
Old Jul 30, 2004 | 09:42 PM
Sqard's Avatar
Your paint is most likely oxidized. You should start off with a compound, then polish, then wax.
Old Jul 31, 2004 | 08:17 AM
PrinzII's Avatar
OG and counting...
a) What part of the Chicagoland area are you in?
I could physically take a look at your car and tell you exactly what to do (dependent on area).
b) Sqard is correct in that you would need a polish to get the oxidation out. However, you will need something strong enough to take care of many paint defects. For your particular situation, I would recommend Meguiar's #83 Dual Action Cleaner Polish and someone with either an orbital like a Porter Cable 7424 or rotary.
Old Jul 31, 2004 | 08:23 PM
I am part of the Hoffman Estates/Schaumburg area. I want to get it done proffesionaly because I don't have time to do it as bad as that sounds.
Old Aug 1, 2004 | 08:04 PM
{-_-}'s Avatar
wouldn't claying it help as well?
Old Aug 1, 2004 | 08:13 PM
PrinzII's Avatar
OG and counting...
http://www.smartpages.com/home/barrington94083240
http://www.smartpages.com/home/deweysauto57285752
PM me because I may have someone else in mind as well.
Old Aug 3, 2004 | 06:36 PM
Bman's Avatar
Not unless it is extremely heavy, white, chalky oxidation, like the kind you typically get with single stage paints.
Old Aug 5, 2004 | 09:31 PM
I went to this one Schaumburg detailing place called Diamond. He told said I needed some wet sanding and that would cost a couple hundred dollars. Do you guys think this is necessary and a good price?
Old Aug 18, 2004 | 07:10 PM
PrinzII's Avatar
OG and counting...
Wetsanding is basically a last resort. Personally, I would not consider that because if someone does not know what they are doing, they could do more damage to your finish than you care to realize.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
doctorpullit
Apr 23, 2017 05:35 AM
Luigi623
Sep 21, 2015 01:42 PM
