Grime From hands on int parts
My MaX is almost 10 years old now and while ive been pretty good about the ext of the car i do nothing more then get into and drive it as far as the int goes.
anyway there is a build up of grime that is on all parts of the int that i have touched over the years. not sure how to describe it other then o vigorus rub will remove it and i am wondering if there is a safe chem that would make cleaning the steering wheel shifter handle brake handle ect easier then spending about 400 hours rubbing this gunk off.
6 parts water and 1 parts woolite. That should clean it. Use a mifrofiber towel, or a deep pile terry cloth towel.
For stubborn dirt, try a Mr Clean Magic Eraser or a "Dobie" scrubbing sponge.
Another products that I think works well on that type of interior dirt is Simplegreen. Just dip your rag into the solution and scrub a little with it. If you can not get the dirt out of the little crevises, then try dipping a soft brissle brush into the solution and scrubbing it that way. You may want to hold a towel underneath or around the area you are working on so the spray from the brush does not fly all over everything else.
Remember to try it out on an area that is hidden BEFORE You go all out with this or any product. Just to make sure it is colerfast and does not change the color of your car.
Hope that helps?
Hope that helps?
derekinthez
Nov 13, 2022 04:00 PM
