Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Weather for Detailing?
Old Oct 6, 2004 | 08:25 AM
Mr. Maxima's Avatar
What is a good or decent tempature to wax and polish our cars? Is the mid or lower 60's ok or is that to cold?
I wanna get this done ASAP.
Thanks guys..
Old Oct 6, 2004 | 09:51 AM
Dr.Monkey1313's Avatar
I personally think that the mid to lower 60's would be too cold. I say that because you may have a hard time buffing the wax off since I don't think it will dry.
If you have a garage, you could put a space heater in there and do it. I have done that before and it worked ok.
Old Oct 6, 2004 | 10:22 AM
Mr. Maxima's Avatar
Are you sure because I have a friend who did it at 55 degrees.. It worked out fine for him..
Can someone else give there input on this.. I really wanna polish and wash tommorow..
Old Oct 6, 2004 | 11:16 AM
Bman's Avatar
Go ahead and do it. If the temperatures are lower and the humidity higher, it just might take longer for waxes to dry (haze over). If you don't want to wait you can probably get away with wiping off the wax as soon as it's applied anyway. It may or may not work the best this way, but the "let dry to a haze" thing isn't always required. Try it on a section and see maybe.
Old Oct 7, 2004 | 02:50 AM
Dave Holmes's Avatar
I'll second Bman's suggestion. A lot of waxes can literally be WOWO (wipe on, wipe off). However, this can affect durability and ease of removal (some will initially smear, so you'll need to buff several times). Remember with waxes to apply a VERY THIN coat. And keep in mind that humidity affects the drying time.
Polishes usually aren't allowed to "haze", but worked in and then removed.
BTW, I detail my car as long as the water in my water hose isn't frozen solid. I've even put my frozen solid water hose in my bathtub to thaw it out, then washed my car. Never have a problem as long as I keep thin coats of wax and turn my MF cloths very frequently.
Dave
Old Oct 7, 2004 | 12:11 PM
white95max's Avatar
I wax my car once a month year round, and I've been in the garage when it's 20 degrees out washing, waxing, cleaning the tires/wheels, engine bay detailing...If you're worried about the wax not drying, then just use a wax that is able to be wiped off wet. The two that pop into my head are Pinnacle Souveran (for dark colors) and Pinnacle Paste Glaz (for light colors). There are others too.
Old Oct 7, 2004 | 03:45 PM
PrinzII's Avatar
OG and counting...
Between 50-70 degrees is ideal detailing temperature. When the temps dip below 50, you won't see me outside doing that.
Old Oct 7, 2004 | 08:42 PM
white95max's Avatar
wuss.
Old Oct 7, 2004 | 10:16 PM
PrinzII's Avatar
OG and counting...
Originally Posted by white95max
wuss.
Why do it outside when you have a connection to do it indoors?
Old Oct 7, 2004 | 10:31 PM
white95max's Avatar
You've got a good point there.
James92SE
142
Jan 2, 2024 09:23 AM
TKHanson
Nov 24, 2018 01:39 AM
lux97Max
Sep 28, 2015 11:18 PM
2kmaximel
Sep 16, 2015 03:19 PM
