Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Black specs on wheels: how to remove?
Old Oct 12, 2004 | 10:10 AM
GoalieKeg's Avatar
I have EVO 5 rims that somehow have black specs all over them. I keep my rims waxed pretty regularly, so I don't understand how these little specs got there. I have tried the clay bar, but that didn't work. Will a compound, or polish get rid of these specs better than a clay bar? Is it possible that my cv boots ripping and spilling out axle grease all over my rims may have something to do with this? Any help would be appreiciated.
Old Oct 12, 2004 | 01:54 PM
RichSpidizzy's Avatar
probably road tar... try one of these:
http://store.auto-geek.net/detpridbugta.html
http://store.auto-geek.net/megoclbugtar1.html
http://store.auto-geek.net/tarminator.html
http://store.yahoo.com/autopia/1z-913910.html
http://store.yahoo.com/autopia/ag-19325.html
http://store.yahoo.com/autopia/wus-89026.html
Old Oct 12, 2004 | 03:16 PM
GoalieKeg's Avatar
Cool, I'll give some bug and tar remover a shot. I got some sittin in my detailing cabinet.
Old Oct 12, 2004 | 07:59 PM
Bman's Avatar
Yeah try tar remover (solvent) or wheel cleaner first. It may be embedded brake dust if it's been a long time since the last cleaning, but it sounds like you take care of them so HOPEFULLY it's just "dirt" of some kind that can be chemically removed.
If not, you'll have to move up to mild paint polishes.
Old Oct 12, 2004 | 08:26 PM
GoalieKeg's Avatar
I clean my car at LEAST once a week, and wax my rims as regularly as I wax my car, so hopefully the chemicals will do it. When I install my Tein Basic coilovers, I'm going to have a detailing day, so I'll work on them then if the bug and tar doesn't work.
Old Oct 14, 2004 | 11:45 AM
so what ended up happening? did the bug/tar remover work?
Old Oct 15, 2004 | 06:27 AM
GoalieKeg's Avatar
I haven't cleaned my car yet this week, so today I'm due. I'll let you know later.
Old Oct 19, 2004 | 08:14 PM
mm7759's Avatar
Just curious....what type of wax are you using on your wheels? Is it just normal wax, or is it something special for wheels (due to the heat buildup)?
Old Oct 20, 2004 | 06:24 AM
GoalieKeg's Avatar
I use meguiars gold class wax. Nothing special about it.
Old Nov 2, 2004 | 05:20 PM
jimz02max's Avatar
I have the same problem w/ my evos. Last spring I was getting them ready to put them on for the summer. I used 1Z polish by Einszett followed up with Klausse all-in-one and then the Highgloss. Spots are still there after using polish. Dammed if I know what it is, just know I have them and can't get rid of them.
Old Nov 3, 2004 | 06:16 AM
GoalieKeg's Avatar
Bug and Tar wouldn't remove my spots. Does any one else have this problem with Evo's?
Old Dec 20, 2004 | 02:03 PM
Bonka's Avatar
Schnell kaputt
I've got those specs on mine
Just washed the car again today (hopefully last one of the year.) This time they're not coming off.
Old Dec 20, 2004 | 05:35 PM
infintishock's Avatar
You may be a bit apprehensive about trying this out, but if the aforementioned don't work I suggest using #0000 steel wool and lightly going over the spots while they're wet and/or soapy. If you're careful, it shouldn't harm the wheel.
Old Dec 23, 2004 | 06:26 AM
can you take some pictures of the problem areas? it may help if we can actually see what we're dealing with here.
Old Dec 23, 2004 | 09:36 AM
rsly33's Avatar
Try claying the spots.
I dunno if the evos are clearcoated or not, but wont steel wool destory it? Doesnt wetsanding wheels remove the clearcoat?
Old Dec 23, 2004 | 12:54 PM
Fine grade steel wool (#0000) is pretty soft, respectively speaking, and I don't think it would remove clearcoat. I've used steel wool as well as scrubby pads (those rough, green pads used for cleaning bathrooms, sinks, dishes, etc.) on wheels in extreme cases and they've always been fine. I'd actually recommend the scrubby pad over the steel wool, it's even softer but just as effective.
Old Dec 23, 2004 | 02:05 PM
Bonka's Avatar
Schnell kaputt
Yep I completely forgot about the green scrub pads. I used them on the stock wheels and they removed the specs fine.
Old Dec 27, 2004 | 11:28 PM
E55AMG2's Avatar
Wat
Steel wool makes fine scratches in the clearcoat. Id try claybarring before I resort to that.
Old Dec 28, 2004 | 09:10 AM
GoalieKeg's Avatar
Claybar didn't work either. I'm convinced that this is some type of road acid that ate away my clearcoat or something.
Old Dec 28, 2004 | 04:30 PM
Max20SE00's Avatar
oh thats it time for new rims, wanna sell them? J/K I would love some evo5's.
Old Dec 28, 2004 | 07:21 PM
GoalieKeg's Avatar
LOL, I wouldn't mind some 19X10 ADR's with a 2" lip on them.
Old Dec 28, 2004 | 10:07 PM
Max20SE00's Avatar
if your ever sellin the evo's then you got a local buyer!
Old Dec 30, 2004 | 08:25 AM
MaximaPolak's Avatar
You sure those aren't chips in the paint or whatever that is.
Old Dec 30, 2004 | 02:32 PM
GoalieKeg's Avatar
Like I said before, I think it's some kind of road corrosion or something.
Old Dec 30, 2004 | 06:54 PM
E55AMG2's Avatar
Wat
I have them too. I think its from the roadwork on the turnpike.
adamgalazka
Feb 5, 2023 08:24 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
ballerchris510
Sep 10, 2015 09:35 PM
doctorpullit
Sep 10, 2015 06:33 PM
03VQMAX
Sep 5, 2015 03:47 PM
