Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
emblem removal
Old Oct 14, 2004 | 10:41 AM
dennisuello's Avatar
emblem removal
are there any tricks to removing the Maxima and GLE emblems from the trunk lid? are they just attached by double-sided tape, or there are any aligning holes in the trunk? anything that will make the removal easier and leave the least residue?
thanks
Old Oct 14, 2004 | 10:44 AM
MaximaPolak's Avatar
thanks
The words: Maxima, GLE, SE, and GXE have no holes and can be removed with heat......The "Burger" on the trunk has holes, so I am told, and will leave visible holes.
Old Oct 14, 2004 | 11:02 AM
NewLoveI30's Avatar
I used heat, fishing line, and WD-40 to remove mine. Then put on a nice coat of wax after claying.
Good luck, and I know you will like it.
Old Oct 14, 2004 | 01:14 PM
SoonerFan's Avatar
Cletus
the holes ARE NOT visible if you fill them in and paint over them
Old Oct 14, 2004 | 01:24 PM
Puppetmaster's Avatar
I just used floss and Goof Off for the "Maxima SE"...
Old Oct 14, 2004 | 01:53 PM
krmaxima's Avatar
did u use heat puppetmaster???
Old Oct 14, 2004 | 01:57 PM
Max20SE00's Avatar
all i did was pry mine off and polished it up worked perfect.
No generated heat, if that's what you're asking... but it was probably like 80-90 degs out when I did it.... so its not like I did it on a cold winter day.... I do think that you need a certain degree of warmth for the stuff to give when you're "flossing" it...
Old Oct 14, 2004 | 03:34 PM
MIXXMAX's Avatar
Removing the hamburger one on the trunk lid looks kind of wierd because of the empty space it leaves. That little "dip" where the emblem is shaped above the license plate, stands out more.
Old Oct 14, 2004 | 03:54 PM
lex3015's Avatar
i didn't even bother with heat, i used fishing line and then a buffing compound to get rid of the glue
Old Oct 14, 2004 | 10:07 PM
I agree... but Soonerfan's looks pretty good....
Old Oct 14, 2004 | 10:09 PM
Yeah I guess that'll work too... I just found it easier doing it when it was warm out.... glue was slightly "softer"...
Old Oct 14, 2004 | 10:50 PM
turbo_gg's Avatar
Talk about timing. I just took off my trunk lid Maxima and Nissan Emblems tonight. I replaced the Nissan emblem (thereby covering the two holes) with the Maxima emblem from Custom Enterprise, it looks very unique and cool!!
I left the SE emblem on for now. I also took off the front Nissan emblem and put another Maxima emblem up front. Much nicer looking than that generic Nissan emblem!!They are all attached by nothing else but double sided tape. I used dental floss and a little heat, and everything came right off, no problem.
Old Oct 14, 2004 | 10:54 PM
I left the SE emblem on for now. I also took off the front Nissan emblem and put another Maxima emblem up front. Much nicer looking than that generic Nissan emblem!!They are all attached by nothing else but double sided tape. I used dental floss and a little heat,a and everything came right off, no problem.
Got pics??
Old Oct 15, 2004 | 12:52 AM
turbo_gg's Avatar
Not yet. I'm waiting to lower my Max, then take some pics with my Turbo Supra and post em up!!
Old Oct 15, 2004 | 01:04 PM
SoonerFan's Avatar
Cletus
thank you.
i actually just ordered a nissan emblem from an 03 pathfinder. its about half the size.
and it sticks on in case i want to remove it later. will post pic after i get and install it.
REDinLV
Aug 15, 2024 12:30 AM
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
