Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Klasse Question...
Old Nov 17, 2004 | 10:40 AM
matty's Avatar
Klasse Question...
What one goes first...sealant glaze or the other one (cant think of it off the top of my head)
-matt
Old Nov 17, 2004 | 12:05 PM
808SE's Avatar
AIO first, SG second.
Old Nov 18, 2004 | 11:09 AM
BensMax93's Avatar
AIO = polish, clean paint.
SG = sealant for the paint.
-Ben
Old Nov 18, 2004 | 10:29 PM
matty's Avatar
I thaught it was the other way around because on the back of the sealant glaze bottle is sais for extra protection use All In One after the SG goes on
-matt
Old Nov 19, 2004 | 06:29 AM
PrinzII's Avatar
OG and counting...
Nope. The SG is for extra protection after the AIO. SG is layerable (You can put more than one coat). I have seen people on Autopia put 3 layers of SG on their cars.
The AIO not only polishes but sets the surface up for the SG.
Old Nov 19, 2004 | 09:39 AM
matty's Avatar
Well I did one coat of it last nigth and I may do another tonight...would be it best to add a top coat of Meguiers NXT wax or the P31S stuff ?? This is the last time ill be able to detail it till the spring most likely
-matt
Old Nov 19, 2004 | 11:20 AM
steaLthyMax's Avatar
Some people say its best to wait a week between layers of SG to allow for it to fully cure..dont use NXT on top of the AIO and SG..the NXT has polymers in it which can be used as a mild cleaner..look for a wax with no cleaning polymers in it..something like Pinnacle or Meguiars #26
Old Nov 20, 2004 | 07:37 AM
PrinzII's Avatar
OG and counting...
I'd recommend the P21S/S100 or the Pinnacle Waxes. The key thing is that you want a wax that is carnuba and has no cleaning properties like NXT.
Old Nov 20, 2004 | 06:12 PM
white95max's Avatar
I would say use the AIO, then SG, let it cure for a few days, then use S100, P21S, #26, #16, Paste Glaz, or some other durable PURE wax.
Old Nov 20, 2004 | 08:57 PM
E55AMG2's Avatar
Wat
No curing necessary, you can put the topper wax on pretty much right away
Old Nov 20, 2004 | 11:12 PM
white95max's Avatar
You don't let the sealant cure before applying a topper? Do you also not let the sealant cure before adding another sealant layer?
Old Nov 21, 2004 | 04:51 AM
E55AMG2's Avatar
Wat
This is the beautiful part about sealants. They dont really require curing time. The only stuff I have seen that really required it was this liquid glass stuff that I saw at discount auto parts. When I do the klasse, I do 2 thin layers of the SG topped off with a nice thin coat of S-100. Car is simply amazing.
Old Nov 21, 2004 | 08:32 AM
PrinzII's Avatar
OG and counting...
Not so fast. I'd let the SG cure a minimum of 30 minutes before applying anything else to it. Also, a very slick thing to do is to mist a QD onto a MF when removing SG. This reduces the possibility of the "Klasse Haze" and makes removing the SG easier.
Old Nov 21, 2004 | 08:35 AM
E55AMG2's Avatar
Wat
I dont even think it needs that long man, Ive seen where it takes anywhere between 8-12 min to be ready for a top wax. Perhaps you use a thicker coat than I do?
Old Nov 21, 2004 | 08:38 AM
matty's Avatar
Whats that ??
Is it ok to wait a week before the top coat of wax goes on.?? or do I need another coat of SG before that last wax goes on ??
-matt
Old Nov 21, 2004 | 08:40 AM
PrinzII's Avatar
OG and counting...
No, my fellow mod. I don't. Besides, I know if you use Zaino with ZFX, you get the instantaneous cure time but not with Klasse.
Old Nov 21, 2004 | 08:45 AM
PrinzII's Avatar
OG and counting...
Originally Posted by matty
Whats that ??
-matt
Since you are from virtually the same climate as I am, I'd advise putting a second or even third coat of the SG onto the finish for additional protection and then put the wax after the second or third coat of SG.
The QD (Quick Detailer) misted onto the MF (Microfiber Towel) will make the SG very easy to remove.
Old Nov 21, 2004 | 08:52 AM
matty's Avatar
Well for the second and third coat of SG do I need a setting up time between them or no ???
-matt
Old Nov 21, 2004 | 10:29 AM
E55AMG2's Avatar
Wat
I believe you need a few minutes
Old Nov 21, 2004 | 10:31 AM
E55AMG2's Avatar
Wat
Noted...
[10char]
Old Nov 21, 2004 | 10:44 AM
PrinzII's Avatar
OG and counting...
-matt
I usually let it cure for a day before putting the second coat on. When I did my '94 Maxima with AIO/SG, I let a day go by before putting the second coat on and then probably a week before the third.
Old Aug 10, 2008 | 10:40 PM
slimbim's Avatar
First, many thanks to all of you for sharing your expertise. If I wait a day after the first coat of SG, how should I wash/prep the car for the second SG coat provided it has not rained? Should I just dust the car with a dry cloth or something more?
Old Sep 3, 2008 | 03:01 AM
PrinzII's Avatar
OG and counting...
I would wash it as normal and then apply the new coat of SG.
bluefish
20
Jan 18, 2001 12:24 PM
Naughty
Dec 20, 2000 10:12 AM
Naughty
Dec 5, 2000 12:04 PM
