Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
The Ultimate Detail?
Old Mar 29, 2005 | 04:34 PM
DUKEE's Avatar
Hey guys, im trying to figure out a perfect step by step procedure to wax my car. I've waxed my car once in the past and i would like to know if you could give me any help in these steps that i have wrote. If there in the wrong order or if i am missing a step. Thank you!
THE ULTIMATE DETAIL
1)Hose down car starting from the top of the car to the bottom (Hot or Cold Water?)
2)Remove old wax using Dish Soap mixed with (Hot or Cold Water?) using Chenille Wash Mitts and 2 Buckets
3)Rinse car once more with hose (Hot or Cold Water?)
4)Wash car with **Meguiars Deep Crystal Car Wash** with (Hot or Cold Water?) using Chenille Wash Mitts and 2 Buckets
5)Rinse Car (Hot or Cold Water)?
6)Let dry
7)Touch up paint chips
8)Clay bar? which one?
9)**Mequiars Deep Crystal System Paint Cleaner Step **1, in what motion? linear or circle?
10)**Meguiars Deep Crystal System Polish Step 2**, in what motion? linear or circle?
11)**Meguiars Deep Crystal System Carnauba Wax Step 3**, in what motion? linear or circle?
12)**Meguiars ScratchX**? to remove scratches and swirls or no?
13)The end?
Old Mar 29, 2005 | 07:44 PM
CanadianMoFo's Avatar
The Scratch X should go before the polish and wax. The idea is to remove the scratches before you start putting coats of product on top of them.
Read through the stickys at the top of this forum too. Lots of good info there.
CM.
Old Mar 30, 2005 | 03:46 PM
99se5spd's Avatar
you dont have to do the dish soap wash( and wouldnt reccomend it ever b/c it dries out seals/trim, its just too harsh for a car.) the clay/cleaner/and polish will all remove the old wax and if its been more than 3-6 weeks since you last waxed it it is more than likely totally gone anyway. dont let the car dry, dry it, this will eliminate water spots which can etch into your paint which are very difficult to remove if severe enough. touching up the paint chips you are going to want to let the touch up paint fully dry before sealing them with a wax or sealant, probably about 24 hours dry time. clay bar look in the stickys for product reviews, prinzII did a nice review on clay bars, i would also reccomend clay magic (wal-mart carries it). just use hose water. it is always agood idea to use front to back motions on the top sections and up and down motions on the sides wjhile washing b/c if you do accidently scratch (from dirt on your wash mit) you will be less likely to see it. you will want to use a circular motion for applying every thing else, use tight circles and make sure you have a quality applicator. canadian **** is right if you use the scratch x at the end you will undo all your work, if it needs to be used use after claying. you can also check out autopia.org for all the info you could ever want.
knight_yyz
Nov 6, 2015 02:34 PM
knight_yyz
Oct 24, 2015 08:05 AM
