Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Incredibly sticky sticker
Old Apr 4, 2005 | 03:43 PM
usmanasif's Avatar
I know there is another thread on removing stickers, but this is different. I have a parking sticker on my rear bumper that seems impossible to remove. It is not the paper kind like bumper stickers are. It is that highly reflective, super stretchable kind of sticker. I haven't tried heating it, but using my fingernails removes no more than a mm (not kidding!) of it. What do you guys think?
Old Apr 4, 2005 | 05:14 PM
nismo0604's Avatar
try goo gone
Old Apr 4, 2005 | 06:37 PM
Terran's Avatar
You will need to heat it. Even a hairdryer will work if you can't get your hands on a heatgun.
Old Apr 4, 2005 | 07:35 PM
mtnbikeair's Avatar
I use goop off, it works really good, smells like paint thinner, but works better and doesnt strip paint.
Old Apr 4, 2005 | 09:33 PM
bigbmaxima's Avatar
Originally Posted by nismo0604
try goo gone
go for that stuff it works
Old Apr 5, 2005 | 10:04 AM
GoalieKeg's Avatar
Use either goo gone or 3M adhesive remover. Works wonders.
Old Apr 5, 2005 | 10:31 AM
usmanasif's Avatar
Thanks much guys! I will definitely try the two products mentioned. But my problem is that as it is a plastic-based sticker, I can't even lift an edge to spray the stuff in and let it detach the rest of it. Perhaps heating would help, as suggested by one of you.
Old Apr 5, 2005 | 03:46 PM
Terran's Avatar
Those products are all to get the goo off once the sticker is removed. They also make this eraser wheel thing that might work, but try heat first and if that doesn't work then come back and I'll try to better explain the eraser wheel.
Old Apr 5, 2005 | 06:38 PM
CanadianMoFo's Avatar
I've always had good luck removing heavey sticker residue from windows by freezing it with an ice cube to make it more solid and easier to peel off. Kind of like how you freeze gum on the sidewalk to make it easier to remove.
Old Apr 6, 2005 | 01:13 PM
5alive's Avatar
Do unto others...
Gum?
What do you do with it once you get it off the sidewalk?!
Frozen gum is impossible to chew!!
Old Apr 6, 2005 | 01:22 PM
Give me your mailing address and I'll save it for you. Do you want gritty or extra gritty?
Old Apr 6, 2005 | 01:52 PM
usmanasif's Avatar
Yeah, that's what I meant too. They won't help remove the sticker. I tried the blow dryer; didn't even budge the sticker. So yeah, as you were saying, the eraser wheel.....
Old Apr 6, 2005 | 04:37 PM
Terran's Avatar
really...I'm surprised by that. The sticker was pretty warm right?
I've used the eraser wheel on tough pinstripes, but never a sticker...should work though. It looks like this:
I don't know where you'd get it or even if sticker removal is even it's intended purpose. You'll need a drill of some sort...probably just about any type, be VERY careful if it's a fast one though. Just make sure to keep it moving as I'm sure it could burn paint. start at an edge and see if you can get it to peel the sticker (might not be a bad idea to get the sticker warm first). The eraser will leave residue which is why I prefer to just peel things off. I use mothers prewax cleaner to remove this, but you might even be able to just wash it off.
Old Apr 7, 2005 | 05:17 AM
BK1's Avatar
BK1
Hello
Try spraying on the goo gone and letting it sit. Sometimes the sticker will absorb it and come off easier later.
PH98I30
29
Feb 10, 2025 12:03 PM
BobTX10
Oct 7, 2015 08:43 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
jerrod99_se-l
Aug 22, 2015 04:14 AM
