Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
What removes spray paint?
Old Apr 27, 2005 | 05:44 AM
theMax's Avatar
Short of long story, can of spray paint exploded and is ALL over my car. Paint looks like gray primer.
Any help getting this off? Can I use a paint thinner or do I have to get it buffed off or worse, the car repainted....
Old Apr 27, 2005 | 06:44 AM
ChromeSE5's Avatar
i used brake cleaner... but very small doses.
What happened was I ran over a can of gray primer and the stuff exploded all over my car. Ugly sight, but i got most of it off, if not all.
Old Apr 27, 2005 | 08:37 AM
jcberb's Avatar
Try a clay bar perhaps that will work
Old Apr 27, 2005 | 08:54 AM
DanNY's Avatar
Ad·min·is·tra·tor
if it's still fresh get some 3M bug and tar remover and dab on and see if it comes out.
Old Apr 27, 2005 | 04:41 PM
roll4life's Avatar
buffing won't do anything, maybe try a clay bar..or brake thinner or maybe alcohol or acetone but in suuuuuper small amounts on a napkin or something..but i'd deff try a good clay bar first..good luck man..sorry to hear about that
Old Apr 28, 2005 | 12:53 AM
Dr. Roy's Avatar
clay works pretty good on small paint specs, somehow my car got a bunh of overspray on it, takes abit of elbow grease but it all came off, i guess you could also thry compound on realy heavy areas
Old Apr 28, 2005 | 02:23 AM
PrinzII's Avatar
OG and counting...
Mineral Spirits but in small doses.
Old Apr 30, 2005 | 01:21 PM
jackiss2888's Avatar
clay bar will work, but youll need soem elbow greese. long story short, take tails off the car when doing red/clear repainting. i am the epitamy of laziness...
Old Apr 30, 2005 | 01:28 PM
Dave H.'s Avatar
i had spray paint on my car before and i used goof off. It worked well to take it off and didn't take any paint off. I just had to wax the area after.
Old May 2, 2005 | 07:37 PM
didnt take any paint off, and you say it worked well?
ahh, im jp man . I'm gonna try this stuff cuz there are still specks on the lid.
Old May 15, 2005 | 08:56 AM
theMax's Avatar
Here is a pic of the damage, looks like white primer. Can war rolling around on the road and rolled under my rear wheel. Big cloud of paint got my car and a bunch of others.
Old May 17, 2005 | 11:16 AM
E55AMG2's Avatar
Wat
grafitti remover...try some on an inconspicuous area.
Old May 18, 2005 | 08:26 PM
Duckman540i's Avatar
VE Powah!!!
Wow! Thats alot more than I imagined was on the car. I was gonna say use a Razor Blade & scrape it off, but thats alot more than you would want to do by hand with a razor blade. Maybe ask a bodyshop & see what they say?.........
Old May 18, 2005 | 09:04 PM
xnyc's Avatar
that actually looked pretty cool at first..looks like light is being reflected in water onto your car..id suggest using turtle wax commercial rubbing compound. (should be red on inside) works wonders. try not to over rub it though. will rub your clearcoat off if you do it too much. im almost 100% sure most of it/all of it will come off depending on how well you kno how to use it
edit//
pm me if you want tips on using the compound, otherwise, im assuming you kno how to use it
Old May 19, 2005 | 11:23 AM
MIKE2K2's Avatar
Custom User Title
run over another can on the drivers side to match
Old May 19, 2005 | 11:32 AM
PrinzII's Avatar
OG and counting...
~I still say Mineral spirits to remove the paint and then follow it with a clay bar.
Old May 20, 2005 | 01:56 PM
theMax's Avatar
Spoke with a few body shops and that is what they reccommended. If it did not work they said to use rubbing compound.
I used laquer thinner and it worked real well. I put it on a small area and in about 10 seconds it started wiping right off. After another 10-20 seconds it evaporated and did not remove paint. I worked quick, a small area at a time.I used a rag with the thinner to wipe the paint off, used another damp rag to wipe and excess paint then wash with car soap and water. Got most if it off, just have to get the small paint specs that are ALL over the car, on the roof, rear bumper, windows, etc.
Next a good clay bar, polish and wax, thanks all!
Old May 20, 2005 | 05:16 PM
95bkackmax18s's Avatar
dam, thats nuts. i hope it works out for you and that 'crap' never happens to me.
Old May 23, 2005 | 09:32 PM
Nismo Junkie's Avatar
2 words...GOOF OFF....works....trust me
Old May 25, 2005 | 11:31 AM
JiggsHall's Avatar
I actually own my own detailing business. What's funny is I actually had to get paint off of a customers Max this weekend. I used a mild rubbing compound to get all the paint off. I then buffed it out and the paint was clean. The car was black so it had to be buffed no matter what I did to get it off. If you decide to use rubbing compound, you don't need a whole lot , but judging by the amount of paint you have on the car it's going to take a while.
Old May 25, 2005 | 01:04 PM
scopium
if u look at it in a certain way.. it kinda looks nice..
try.. getting the same effect on the other side..
no but on the serious issue.. have you tried wet sanding?
Old May 27, 2005 | 06:19 PM
theMax's Avatar
I didnt want to use anything abrasive if I didnt have to so I avoided sanding or buffing. The laquer thinner worked good but I still have to get a Qtip and get in some of the cracks. I'm not even going to bother with the bottom of the car....(right now anyway)
Old Jun 1, 2005 | 03:04 PM
95arcticpearl's Avatar
Maybe try overspray or road paint remover
REDinLV
Aug 15, 2024 12:30 AM
Apr 16, 2020 05:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
