Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
How to Clean a Dingy Headliner?
Old May 3, 2005 | 05:57 AM
ghostrider17's Avatar
Anyone have a good method for cleaning the fabric headliner to remove the dinge that has built-up....particulalry around the sunroof area?
Muchimas Gracias!
gr
Old May 3, 2005 | 06:12 AM
mdsmithers's Avatar
6 parts water to 1 part woolite, spray on towel, scrub lightly, vacuum. This can be used anywhere inside your car to clean.
Old May 5, 2005 | 09:27 AM
PrinzII's Avatar
OG and counting...
Actually, you should spray that onto a towel and gently agitate. Too much moisture on the headliner will cause problems down the road.
Old May 8, 2005 | 10:32 AM
E55AMG2's Avatar
Wat
Not to mention more mold.
You may even want to try a carpet extractor then use a hair dryer to dry it out.
Old May 8, 2005 | 11:06 AM
PrinzII's Avatar
OG and counting...
Extractor = That could potentially weaken the glue.
Old May 8, 2005 | 11:11 AM
E55AMG2's Avatar
Wat
hmm, i may wanna go check the car I used one on.......
Old May 8, 2005 | 11:48 AM
gtr_rider's Avatar
192.168.1.1
oh lord..
Old Jan 10, 2006 | 03:43 PM
Jeff92se's Avatar
I'm needing a caw
So what is the best way to clean the headliner? I don't have stains perse but I'm trying to remove a smoke smell.
Old Jan 10, 2006 | 04:50 PM
MrGone's Avatar
Old Jan 10, 2006 | 05:56 PM
ha....i didn't realize that I originally posted this up 8 months ago!
I actually picked-up an aerosol can of Blue Coral Fabric/upholstery cleaner a few months ago at Peppy BOyz.
Works a charm, and smells REAL nice!!
Follow instructions on the can.
I have noticed that the dirt ring on the sunroof slide doesn't stay gone for long however.
gr
Old Jan 16, 2006 | 03:17 PM
4MySwee's Avatar
I know this sounds nuts.....with two kids, I have had to learn the hard way. The miracle cure for headliners is .....prepare yourselves......Tide Pen. It is alcohol, and scrubber all in one, yet gentle enough to use on my last Nissan. (Haven't bought one for this Nissan yet).
Old Jan 26, 2006 | 08:42 AM
Jeff92se's Avatar
I'm needing a caw
I changed the in cabin filter and that didn't help much. The air that came out still smelled like monkey ****. I took off a cover that exposed the fresh air intake. Then sprayed Clorex odor remover w/ the up/bottom vents on, fresh air vent on and with the blower on full blast. So far it seemed to work.
Originally Posted by MrGone
Old Jan 26, 2006 | 10:36 AM
njmodi's Avatar
Do I get a tax break?
It could also be from the build up in the evaporator core maybe? They make some good cleaning products to help clean the core out... I don't remember the names off-hand.
This product requires access to the core directly, as opposed to the method you used with spraying a cleaner into the cowl/intake area.
Old Jan 31, 2006 | 07:20 AM
Maxima Man's Avatar
Where is the in cabin air filter located Jeff92se ?
I would like to change it !!
Old Jan 31, 2006 | 09:40 AM
Jeff92se's Avatar
I'm needing a caw
I was referring to my G35. But if your Maxima does indeed have one, it's located in or behind the glove box.
Apr 16, 2020 05:15 AM
jonreidhead
Jan 6, 2016 09:38 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
