Claybar? does it really work?
Originally Posted by icelandmaxima
My question is on the brand of clay bar, i find it quite expensive to use the California clay bar. Why cant you just use some modeling clay with the lubricant. You pay so much for such a little quantity. To me there is nothing special about the california clay bar in comparison to any other clay. Not to knock the california clay bar cause it works like a charm but it is expensive is it not.
http://www.autopia-carcare.com/inf-clay.html
Detailing clay is an abrasive system. If not used properly, detailing clay can cause light surface marring. There’s no need to fear if you use proper lubrication.
1. Detailing clay works by hydroplaning (floating) over the surface you’re cleaning on a thin layer of clay lubricant.
2. When the clay (polish) encounters surface contamination, it abrasively grinds it away.
3. Detailing clay shears off any foreign material above the level surface of the paint.
The detailing spray works better from my experience... The clay bar seems to "glide" better over the paint when removing contaminants than using water...If you want to get off cheap you can use water but if you want to do it right and remove the grime off your car stick to the spray that came with the bar or use any detailing spray...
Yea I just used the clar bar on my 90 SE and man it took alot of dirt off! I wouldn't be surprised if it hasn't been waxed in over 5 years. It kinda looked like greenish mold coming off. I cant wait untill it gets nice out again so I can do a proper waxing.
~Alex
~Alex
Originally Posted by PrinzII
Actually, the following are almost as bad as bird droppings and need to be removed ASAP:
- Some types of sap
- Eggs
- Certain fruits
- Some types of sap
- Eggs
- Certain fruits
a good alternative to detailing spray is just a mixture of car or dish wash soap mixed with water. this is the only time you would ever use dish washing liquid on your car. I would not recommend using only water as lubrication. Soapy water works just fine. remember to seal the paint afterwards with wax.
Originally Posted by normkit108
can you use water on the claybar or is the detailing spray recommended?
I am also going to add insect fecal matter and squirrel poop to the list.
claybars are awesome....I have a 96 mustang show car that has been cleaned probably 1000 times since I got it in 01, but I had never claybarred it until last year. And as clean and beautiful as it was, I got sooooo much crap out of that paint. They are amazing, and well worth the time you spend using them.
Maxima30
Sep 7, 2015 06:13 PM
