Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Sticker Removal
Old Jul 1, 2005 | 07:59 PM
Tatanko's Avatar
Bacon Lover
Sticker Removal
I have Anti-Theft System stickers on my front 2 side windows. I think they look tacky and I want them off. How can I get those off without leaving a mark behind? What should I use to get rid of any residue left over on the glass?
On a side note...I have numbers etched into all of my windows. What are they for?
Old Jul 2, 2005 | 03:09 AM
Bluesbrekr's Avatar
Doctorate in Detailing
I've used a single edged razor blade on the outside of the windows without any scratching. You could probably do that on the inside too, if you don't have tint.
Goo Gone for the residue.
Old Jul 2, 2005 | 05:34 AM
MdniteDrftr's Avatar
Those numbers are your VIN. Its an anti-theft measure that basically tattoos your car. If it ever gets stolen, its easier to track, and makes it more difficult for *******s... I mean, theives to profit from ripping off your car.
You might also get a break on insurance too.
Old Jul 2, 2005 | 09:14 AM
Tatanko's Avatar
Bacon Lover
Uhhh...def. not my VIN #. I've checked. It's a shorter number, much different from my VIN. I don't think I get a break on insurance, either
Old Jul 2, 2005 | 06:02 PM
Terran's Avatar
Make sure your insurance company nows about those numbers....they're an anti theft measure and should get a discount.
As long as your windows aren't tinted then do as Bluesbrekr says and scrape off with a razor blade then spray a window cleaner on (I've only done this with the foaming type...don't know if that's a requirement) and scrape the residue off with the razor.
Old Jul 8, 2005 | 10:00 AM
a1lama's Avatar
wd40 takes residue off quite easily
Old Jul 9, 2005 | 12:28 PM
HoldTight's Avatar
Warning!!
WARNING!! Make sure you use a new razor blade this is very important. A new blade will not scratch your glass.
HoldTight...
Old Jul 9, 2005 | 06:07 PM
aBoZoG's Avatar
O have done this more then 20 times, simple razor n windex... you r good!
Old Jul 12, 2005 | 11:00 PM
Tsukuba_Circuit's Avatar
If all else fails, I've found "un-du ADHESIVE REMOVER" does wonders for removing stickers, labels, parking permits etc from glass windows. I don't know if it's safe for use on window tint film so beware. There shouldn't be anything applied to tint anyways so you should be ok. If you wait till the glass is nice and hot on a summer day, it makes the removal process a bit easier since it heats up the adhesive that you're trying to remove. You could probably find this "un-du" stuff at a local office supply store or a neighborhood drug store. Also, I've used mild steel wool along with the "un-du" solution for tough jobs and got good results. Don't touch the steel wool to the paint...only glass! Good luck.
Old Jul 12, 2005 | 11:19 PM
BlueC's Avatar
wat
use a fresh razor blade and some 3M adhesive remover and you are set.
Old Jul 13, 2005 | 05:33 PM
RockfordMax's Avatar
Back from the dead
spray-nine and a razor!
Old Jul 18, 2005 | 06:33 PM
XtinctWS6's Avatar
sweet i needed help with the same thing, completely forgot about goo gon
Old Jul 18, 2005 | 07:46 PM
95maximan's Avatar
wow someone else uses spraynine.. that stuff rules the world..
Old Jul 19, 2005 | 02:59 PM
Terran's Avatar
Link please. Is it just a glass cleaner?
Old Jul 21, 2005 | 09:29 PM
rjb22's Avatar
plastic razor blade and some windex will work
Old Jul 23, 2005 | 02:17 AM
wheeldream76's Avatar
Goo_Gone used to work but i no longer have any luck with it when cleaning old stickers.
Razor blade seems to be the best solution but you must be very careful
Old Jul 26, 2005 | 08:22 PM
bigsherv's Avatar
what they said
Old Jul 27, 2005 | 02:35 PM
Terran's Avatar
Originally Posted by bigsherv
what they said
Wow. That was helpful.
Old Aug 4, 2005 | 09:25 AM
ghettoblast76's Avatar
so many options
Old Aug 10, 2005 | 06:48 AM
Vtwinsports's Avatar
Goof off and razor is what I use.
Old Aug 11, 2005 | 07:50 PM
Tatanko's Avatar
Bacon Lover
Haha...I can't believe this thread is still going. I took those stickers off forever ago just by using my fingers and windex
Old Aug 12, 2005 | 01:12 PM
wetzelman1's Avatar
Use a hairdryer on it also. The heat makes the adhesive become sticky and is alot easier to remove. I removed some stickers from my bumper on ym old car and you can't even tell that there was anything there.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
