Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Headlights + Goo-Gone = BAD
Old Jul 11, 2005 | 06:27 AM
GujuGuy67's Avatar
Out of the goodness of her heart, my sister decided she would do me a favor and clean my car. (She actually owed me money and I decided to knock off a hundred if she did.) Anyways as I was saying, she cleaned it pretty well, however she cleaned my headlights with Goo-Gone thinking that would make them shine again. The end result is that my headlights are heavily covered with scratches and blemishes.
Are there any solutions to get rid of this? I tried washing with various chemicals, letting water run, using polish, using a paste, but nothing seems to work.
Well if there aren't any solutions, can anyone suggest a place to get a set of headlights mildly cheap for a 98 max?
Old Jul 11, 2005 | 06:34 AM
TXT-1's Avatar
What year Maxima do you have?
Old Jul 11, 2005 | 06:35 AM
MDeezy's Avatar
Why did she use Goo-Gone on the headlights?
Maybe light sanding might help
for cheap headlights check the for sale, junk yard, or ebay. Also your pretty nice to knock off $100 if she cleaned your car.
Old Jul 11, 2005 | 06:36 AM
GujuGuy67's Avatar
98
Edited in original post as well
Old Jul 11, 2005 | 07:12 AM
Tatanko's Avatar
Bacon Lover
Tell her you're not knocking off $100 now, and that she needs to buy you new headlights instead
Old Jul 11, 2005 | 07:21 AM
instil's Avatar
try that Plastx....i forget who makes it , meguires perhaps. they have it at the auto parts store. I hear very good things about it, im gonna get some to unhaze my headlights
Old Jul 11, 2005 | 07:43 AM
s0ber's Avatar
Googone probably wouldnt have done nothing on Glass, but since your lights are plastic, I assume its like hitting them with sandpaper... So, to remove it, use sandpaper..
Sand the lights down to a polish, im thinknig 800-2000grit and then throw on alot of plastic polish, or rubbing compound should work?
Old Jul 11, 2005 | 08:39 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Most likely Novus plastic cleaner and then the polish will clean them up. A little easier to find would be the meguiars version, which should work as well.
Old Jul 11, 2005 | 08:48 AM
meanbean's Avatar
+ 1. I recently used Goo-Gone to remove some tar on my headlights and after I was done I had a nice haze to show for it. I hit it with some plastic cleaner and then some polish and its was good as new again. Good luck to you.
Old Jul 11, 2005 | 01:17 PM
MaximaPolak's Avatar
3M plastic polish and plastic cleaner.
Old Jul 11, 2005 | 02:02 PM
wngan9447's Avatar
Chicken Feet Croo!
Sounds like a similar i had not too long ago... i just used bug&tar remover from turtle wax.. it said on the lable that plastic was kool... then find some kind of polish for it at the auto store
Old Jul 11, 2005 | 02:09 PM
ImmaSquashYou's Avatar
use meguairs mag n aluminum polish for steel. it works pretty well. you will have light scratches afterwards. then just use a scratch remover n then a waxer. hope that helps you. oh, i used goof-off and goo-gone on my mom's minivan, it was already messed up so i tried anything. then i used the mag n aluminun polish, worked great!!! n then i used it on my car..hehehehehehe
Old Jul 11, 2005 | 02:26 PM
zax 20th ae's Avatar
Yes that stuff works like a charm!!!!!
Old Jul 11, 2005 | 03:14 PM
nismatic96
i can never find plastx, anyone have an online site to order it from
Old Jul 11, 2005 | 08:56 PM
GujuGuy67's Avatar
Went to an autozone; they had these pads that I just hook onto my drill and it buffs up my headlight...
It does take effort, but it removes scratches as well. Its beginning to look as good as new.
Old Jul 12, 2005 | 09:16 AM
Maxrider24/7's Avatar
Thats stinks the stuff is really powerful, well its a lesson learned, expensive one too
Old Jul 12, 2005 | 09:32 AM
PrinzII's Avatar
OG and counting...
I'd recommend the Novus for this particular issue. Start with Novus 3, go to Novus 2 and finish up with Novus 1.
Old Jul 23, 2005 | 02:22 AM
wheeldream76's Avatar
Note to self : put goo-gone in garbage can. This stuff really doesn't do the miracles it used to do in the old days....
Old Jul 26, 2005 | 08:20 PM
bigsherv's Avatar
mothers make a great clear palstic polish. try that.
Old Jul 28, 2005 | 01:31 PM
bvenvert's Avatar
Mothers or Plastix
You can find the plastic polish online and it works very well on the headlights, taillights, side markers, etc. I bought both brands over the net and tested them against each other on my 4 wheeler. Since a 4 wheeler has plastic body panels, I figured these products would help clean them up. It worked pretty well on a sun bleached old 4 wheeler.
The Plastix brand worked a little better than the Mother's, but either one should clean up your headlights.
AaronL
Nov 15, 2020 11:52 AM
MaxLife17
Jun 27, 2019 01:37 PM
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
