Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Need recommendations....
Old Sep 5, 2005 | 01:12 AM
DuMKuH's Avatar
I want to do a complite detail of the car(from wash to wax and polish) so I would like to hear any recommendations for the products I should use for each step or which set if there are the best one? Thanks in advance!
Old Sep 7, 2005 | 07:45 AM
DuMKuH's Avatar
1234567890
Old Sep 7, 2005 | 08:03 AM
Bluesbrekr's Avatar
Doctorate in Detailing
There's a lot of info on this topic in this forum. I'll tell you what I'd do, but I suggest you look through the posts to find more detailed info.
Wash- Maguiers Gold Class. Some use Dawn to supposedly strip the wax, but the polish will do that.
Clay Bar- many different brands
Polish (may take 2 types depending on how bad the paint is) I use Menzerna, but there are a lot of others.
Wax- S100 (or Souveran if you want to spend more $$)
Old Sep 7, 2005 | 08:27 AM
PrinzII's Avatar
OG and counting...
The key thing before you undertake this project is to figure out how bad the paint is. do you have a lot of scratches or swirl marks? Water spots? Bird bomb etching? Once you determine that, you determine which polish you will need to take it out.
Old Sep 7, 2005 | 05:29 PM
DuMKuH's Avatar
Thanks guys!
Old Sep 9, 2005 | 04:34 PM
DTinVA's Avatar
Ok, say I have some of all you mention, nothing too bad, but noticable when you really look. What polish would do the trick?
I'm also a little fuzzy on the order here: clay bar, polish, wax, polymer sealant? Or should the order be different? I don't want to repeat past detailing errors and appreciate the feedback!
Old Sep 27, 2005 | 01:20 PM
PrinzII's Avatar
OG and counting...
^^ Exactly what you need to order. For your situation, I would recommend either of the following polishes:
- Meguiar's #83 Dual Action Cleaner Polish
- Poorboys SSR 2.5 and SSR 1
- Sonus SFX-1, 2, and 3
- Menzerna Intensive and Final Polish
Bear in mind, many of the above require a machine to work effectively. If this is your first foray, I recommend purchasing a PC and pads. Case in point, Porter Cable 7424 Polisher and Pads.
