Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Looking for wetsanding tips
Old Nov 1, 2005 | 06:08 PM
maxspeedse02's Avatar
Thinks he is fast
I need to wetsand my headlights before they get any worse. I have no experience doing this so any help is appreciated. Also any ideas on where I can get 1000+grit sandpaper from locally? I called lowes and sherwin williams with no luck. I've seen them online but only 50+ sheets and I want 1000 grit 1200 grit 1500 grit and 2000 grit. Does anyone have some laying around I have paypal. PM me.
Ryan
Old Nov 1, 2005 | 06:39 PM
MetaOrbit's Avatar
Got Projectors?
Try Autozone, Pep Boys, O'Reilly's, etc. I've gotten up to 2000 grit from at least one of those places before
Old Nov 2, 2005 | 06:26 AM
mdsmithers's Avatar
Try another paint store, if you still can't get what you need then I can help. PM me
Old Nov 2, 2005 | 02:12 PM
Thinks he is fast
I found it at advance auto (formerly discount auto). I called lowes, home depot, NAPA, carquest, sherwin williams, autozone and finally got some at advance. I also bought platicx by meguiars. I'm looking forward to these headlights looking new again. They sure did look sweet brand new.
Old Nov 2, 2005 | 03:21 PM
CreativeDesignz's Avatar
dude just use heavy cut rubbing compound...no need to go crazy with wet sanding. i used fine cut and it just took a little longer (5 minutes total)
Old Nov 2, 2005 | 08:26 PM
mdsmithers's Avatar
may I suggest you check this thread;
http://forums.maxima.org/showthread.php?t=431901
In my post I have linked what I consider to be one of the best write ups on Autopia, check that for tips and post questions to the Grz, he's got some good experience.
Old Nov 2, 2005 | 10:49 PM
86maxima96's Avatar
I Broke OT
this is kinda off topic, but also kinda relevant.
i am wet-sanding my valve cover and hopefully my upper IM in the near future.
i'm just misting the VC w/ water and then i'm sanding with Metalsand sandpaper. it was a variety back from Home Depot starting with coarse - medium - fine.
do i'm just sanding and then every once and a while (after 5 mins or so) i take the VC to the sink and rinse it all down, dry it off and then go at it again.
Does this sound right? so far, after probably 15 minutes total i am seeing a lot of difference. much smoother and more silver than a dull gray.
sorry if this kinda jacked the thread, but is this the correct process for wet sanding? (metal, specifically).
Old Nov 3, 2005 | 08:07 PM
86maxima96's Avatar
I Broke OT
bump... any tips?
Old Nov 6, 2005 | 11:04 AM
SiriusRIMZ's Avatar
Autozone has 400,600,800,1000,1500, and 2000 Imperial 3M Wet/Dry Sanding papers. I've done this to my jeep's headlight and the results are descent.
Here's my procedure I aquired over time...
Remove your headlamps from the car, disconnect the harnesses. (Unless you want to risk accidently slipping and sanding your finish). I did mine under a stream of cool running hose water, but it can be done anywhere, just consider the mess you'll make.
Put some tape over the holes with the light plug in, and make sure water cant get in there, waterspots on the inside of your housing will be aggravating. Start with some 600 grit to get all the deep pitting out and the discoloration out. You will likely be sanding through the nautral UV protectant in the headlamp housing so after you finish I'd reccomend a weekly waxing to mantain its transparentness.
After your satisfied with your work with 600 grit, move up to 1200, or something close. Again wet sanding out all the 600 grit scratches and cleaning up the lights. They should start to look better, but hazy.
Now move up to 2000 grit, and repeat the wet sanding until the entire housing has been sanded with 2000 grit. At this point, a lot of people would use a rubbing compound followed by a wax, but I used a platic polish.
I first used Meguiars #10 and then #18 to polish them up. I'll up load picture later, at the moment I am digital-camera-less. Edit: I used #10 and 18, not 17.
Old Nov 20, 2005 | 11:51 AM
ramdaspadhye's Avatar
after you use 2k grit, you can just use a medium cut rubbing compound with a porter cable yellow cutting disc, then use a fine cut RC, then just use some hand glaze from 3m, let it sit, then wax the *****es. It'll stay for a while
rbuswell
Nov 12, 2016 04:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dcam0326
Sep 18, 2015 04:52 PM
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
