Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Clean Rims
Old Nov 29, 2005 | 09:49 PM
AceofSpds's Avatar
wat
Clean Rims
What do you guys reccomend for cleaning your alloy rims?
Old Nov 30, 2005 | 06:30 AM
01Bblack's Avatar
I'm **** about my rims- BMW sells a wonderful wheel cleaner- a mild acid- but simple green also works wonders. For the inside of the wheel where buildup causes it to look black from break dust, i use sos pads (will show light surface scratches- but its inside the wheel- and it will look new after cleaning). **do not use sos on the face/lip of your wheel!** after removing all break dust- i like to throw a couple coats of wax on to make the cleaning job easier in the future.
Old Nov 30, 2005 | 02:16 PM
AceofSpds's Avatar
wat
yeah my friend gave me a bottle of some acid that they use at auto detail places i didnt know if it would be a smart move to use it, thanks for the input
Old Nov 30, 2005 | 03:43 PM
01Bblack's Avatar
Ask him if it needs to be mixed with water- to neutralize the acid a little bit- If it is straight acid it will smoke :-p Use acid occasionally- but don't make it a habit (it will eat away at your finish)
Old Dec 1, 2005 | 07:41 PM
AceofSpds's Avatar
wat
hmmm does ne 1 remember the rule for adding acid w/ water
do you pour water in the acid
or pour the acid in the water
i remember that one of them is a really bad thing to do from chemistry class
Old Dec 1, 2005 | 08:16 PM
rsly33's Avatar
For wheel cleaners, it doesnt matter. Acid cleaner is not a straight up acid, but is harsh and could stain/ruin wheels. Dilute it 50/50 to be safe
Old Dec 3, 2005 | 07:16 PM
AceofSpds's Avatar
wat
Hey i have another question, i saw some nice rims in the junkyard but they had corrosion on them, id get em but before i do how or can you get that corrosion off or out
Old Dec 4, 2005 | 01:43 PM
rsly33's Avatar
If you could get pics that would help, but most likely the corrosion is etched into the wheel and would be very hard to remove. If they are alloy, you can get them chemically treated and that is supposed to work very well
Old Dec 10, 2005 | 05:58 AM
Mikey Likes It's Avatar
soap and water
Old Dec 16, 2005 | 05:37 PM
Chucks98's Avatar
Simple Green..............never occured to me to use that stuff on my wheels. I've been using that cheep green 2001 stuff
Old Jan 9, 2006 | 09:51 PM
gle w/o sunroof's Avatar
Originally Posted by Mikey Likes It
soap and water
Old Jan 23, 2006 | 02:54 PM
kraimer21's Avatar
simple green is by far the easiest and most effective method!!!!!!!
Old Jan 23, 2006 | 03:30 PM
Y2k2maxse's Avatar
i do the same as 01bblack. clean the outside with a general purpose cleaner (bmw uses acid cuz they have HUGE brakes which generate tons of brake dust) and clean the inside with compound and a rag, (after cleaning the surface dust off with all purpose) than i waxed the outside and inside of the rims, so next time you have brake dust you can wipe it off with a dry rag (literally) works great
Old Jan 23, 2006 | 05:48 PM
njmodi's Avatar
Do I get a tax break?
Just be sure that whatever off-the-shelf wheel cleaner you use is safe for clearcoats... I used something years ago on my honeycombs and it basically destroyed the clearcoat...
Old Jan 24, 2006 | 04:23 AM
Swisscheese's Avatar
Aww, a little elbow grease and an old rag gets em clean, and builds character.
Old Jan 24, 2006 | 01:56 PM
PrinzII's Avatar
OG and counting...
I have two products I use dependent on the type of rim I run across. Normally, I use Eimann Fabrik's Hi Intensity which does a pretty good job of cleaning brake dust. I also own a bottle of P21S Gel wheel cleaner.
Old Jan 25, 2006 | 10:50 PM
Firemanpato's Avatar
You pour the acid into the water of course!!!! Do I win a prize or anything.
Acid works good, just make sure it's a little dilute.
Old Jan 26, 2006 | 05:11 AM
aussie983's Avatar
Only if its reallly concentrated as a measure of safety. Otherwise it does heat up real fast and explodes if u add water to really concetrated acid.
Old Feb 17, 2006 | 06:17 PM
WhiteMaxima9600's Avatar
Yeah, long as it's safe for clearcoats any kind of wheel cleaner does the trick. Polish them up with some mothers best cleaner.
Old Feb 18, 2006 | 04:54 PM
CanadianMoFo's Avatar
Behold how clean it gets with you get crazy one night with a sweet industrial high temperature steam cleaner! Oh yeah baby...you could eat off these bad boys now!
CM.
Old Feb 26, 2006 | 04:00 PM
AscendantMax's Avatar
damn that wheel is pretty clean...ah the power of steam...
Old Mar 13, 2006 | 11:19 AM
Cdg2125's Avatar
That wheel looks great!
I've been using Mother's Wheel Cleaner with some elbow grease. Then go over it with the powerball and Mothers alloy polish.
Old Mar 13, 2006 | 11:22 AM
Bow down to the power of steam bishes!
Old Mar 13, 2006 | 10:47 PM
MorpheusZero's Avatar
^Hehe, I wanna do that to my rear 300zxtt wheels now before I put em on. I was thinking of just scrubbing and scrubbing...
Old Mar 15, 2006 | 06:37 PM
dawalkster's Avatar
is craving Bojangles
i spray on with orange blast (similar to simple green i think) to loosen things up a bit then just soap and alot of water and scrubbing. i have a wheel brush that works well but after i get the majority of the dust off i clean the rest by hand with water/comet powder mixture.
Old Mar 17, 2006 | 05:23 PM
machinehead's Avatar
i scrubbed my rims for like 2 hours today, they still look like crap. but thats cuz i neglected them for like 6 months and i have some non oem brake pads that are dusty as hell. Im gonna try tomorrow with the meguiars crap
Old Mar 17, 2006 | 06:02 PM
VIP Maxima
i only use soap and water + brush
Old Mar 17, 2006 | 07:12 PM
Cdg2125's Avatar
How's simple green on rims? I have a bottle for the engine bay and I was thinking of using it on my rims before I use the powerball and mothers cleaner? Figured it would cut through that break dust well. Any thoughts?
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
