Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Troublesome Headliner...
Old Mar 17, 2006 | 11:36 AM
BigL0U's Avatar
So i noticed just a few stains and pen marking on my headliner..so went ahead as recommended to use Blue Coral - Upholstery Cleaner - Dri Clean Plus .... sprayed some on a clean terry cloth and gently rubbed it on the stains. worked fine. apparently i also noticed some debris that seems like a smokers cause but i dont smoke nor would i allow anyone else to. tried to get rid of the residue and it took off a good amount it which was noticed on the white rag ...however, now theres a patch of what looks like large water stain. did it not dry well enough? should i re-apply and use a light blow dryer on it? i wanna leave that whole headliner spotless considering that ive noticed more dirty areas on it and yea im aware that i should just clean partial areas at a time. help.help.help.
Old Mar 17, 2006 | 11:51 AM
HoustonHrdHittr's Avatar
I used tuff stuff on my headliner and it did the same thing. So i went and did it again with less foam and it sort of took it out, but i don't think it fixed the problem all together. But i think we may just have to live with it, besides more than likely you are the only one that will ever notice it is there.
Old Mar 17, 2006 | 02:38 PM
BigL0U's Avatar
thanks ... by any chance... anyone used a steamer their headliner? where i can get/rent one!?
Old Mar 17, 2006 | 03:16 PM
Hoooper
just guessing but that may be a bad idea, could loosen some of the adhesive for the liner and make it saggy.
Old Mar 17, 2006 | 04:45 PM
BigL0U's Avatar
Yup very possible .... would want that ... so is there anything better than Blue Coral - Upholstery Cleaner - Dri Clean Plus? Do MicroFiber rags make much of a difference? i was using white terry cloth rags ...
Old Mar 18, 2006 | 01:32 AM
Bluesbrekr's Avatar
Doctorate in Detailing
Hoooper is correct. You want to use as little moisture or liquid as possible on the headliner.
I have had good luck with a Woolite/water mixture. Just spray a small amount on a cloth (terry or MF) and gently rub the headliner. Turn the cloth often.
Old Mar 18, 2006 | 04:14 PM
BigL0U's Avatar
hmm havent tried a MF cloth...think ill give that a shot .... thanks ....
GnomeChompski18
Dec 25, 2014 01:03 AM
joem01
May 13, 2014 04:40 PM
nismopc
Oct 29, 2010 09:40 AM
GETukrainian
Sep 2, 2009 11:57 AM
matty
Detailing
Mar 19, 2007 04:48 PM
