Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Painting Dashboard - Materials
Old Sep 2, 2006 | 12:53 PM
shadyonedeath's Avatar
There's a How-to on VQpower.com about painting your dashboard to look like this :
Well, it suggest to use Dupli-Color High performance Wheel paint, and not where to find it, since its a short right up.
I went to Home-depot, All American, True-Value, and a Auto-paint store nearby, none of them carried it. The auto-paint store didnt sell spray cans so that cancels them out.
From the people who already did this mod, Where did you find your Dupli-color wheel paint? Or what substitute did you use? He suggested to use that specific one because its very durable and prevents cracking/chipping/etc.
Thanks a bunch.
EDIT : Oh wow, i cant believe i forgot to check auto-zone. Brb, but if you have info, post for future users who are intrested in the mod.
Old Sep 2, 2006 | 01:51 PM
Kragen carries ALOT of Dupli-color Spray paints. I just picked one up and about to start my project.
Auto-zone did NOT have it. Grrr.
On the Painting Dashboard modifcation :
http://www.vqpower.com/v2/modules.ph...howpage&pid=55
He has a manual Climate Control.
I have a Auto-climate control, and when removing it, there is a black tube that connects to the back-right side.
Any tips on how to remove it?
And what is it for?
Old Sep 2, 2006 | 01:53 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Any duplicolor will do, I recommend the following:
(1) 320 grit sanding to remove OEM finish
(2) Duplicolor Primer (the grey stuff) to level out any sanding sratches and for proper paint adhesion.
(3) 500-grit wetsand
(4) Acetone wipedown to remove all sand/oils
(5) Paint with color of you choice
(6) Duplicolor clear coat
...you could probably bypass the clearcoat setp if you went with the caliper paint, but I highly recommend taking the aforementioned steps for preparation .
Good luck!
Old Sep 2, 2006 | 02:08 PM
oh crap.
The website said a High grit paper, didnt specify, so i picked up 1500.
Um...will this have any affect?
Old Sep 2, 2006 | 08:28 PM
djfrestyl's Avatar
Suspension Yoda
Probably not. Grits that high are used for body sanding and headlight polishing, etc.
Old Sep 3, 2006 | 03:46 AM
What grit do you suggest?
Old Sep 3, 2006 | 06:30 AM
Right. Like DJ said, higher grits are used more for polishing...NOT for removing any existing finishes. Anything under 500 grit will suffice, although 320 is really ideal in this situation...anything lower will really cut into the surface and anything over is going to take an unreasonably long period of time to do.
Old Sep 3, 2006 | 12:27 PM
The only Primer i have is Rust-oleum Professional Primer. For use on bare metals previously painted or sound rusted surfaces
I really dont want to run out and buy another one since i have like 3 cans of these in my garage.
Is the primer phase really necessary? it didnt state it in the How-To.
Also, Would the primer i currently have work on plastic?
Old Sep 3, 2006 | 03:43 PM
ok,I started painting the pieces without primer.
I've done a test sample on the passenger window controller trim, and it looks great. It looks Smooth, but it Feels ROUGH.
Is it supposed to be like this?
Any suggestions? im kind of short on time so reply ASAP.
Old Sep 3, 2006 | 04:08 PM
djfrestyl's Avatar
Suspension Yoda
Impatience never got anyone anywhere. Should have primed. To get rid of the roughness, wetsand, but don't be surprised if it takes the paint right off.
Good luck
Old Sep 3, 2006 | 04:15 PM
Yea well, i just followed the articles direction.
And i only have a metal primer. will it work?
thanks dj.
Old Sep 3, 2006 | 04:16 PM
djfrestyl's Avatar
Suspension Yoda
Metal primer...it will work better than nothing, but it won't work like what you want it to work like. Cough up the $4, seriously.
Old Sep 3, 2006 | 06:18 PM
shady, I fully agreee with Dj. Cough up the dough and get the correct primer.
Old Sep 3, 2006 | 06:28 PM
Yea, Thanks guys. I know, im stubborn, haha.
Well here's a short update :
I completed spraying the side door panel parts w/out primer. They turned out good, but a lil rough to the touch.
Now, i just bought Dupli-color Sandable Primer for about 6$. I'm going to start the head piece and the gauge part now.
Wish me luck.
Any other tips for priming appreciated. Can never be too prepared.
Old Sep 3, 2006 | 06:35 PM
djfrestyl's Avatar
Suspension Yoda
Here's more more tip...
Old Sep 6, 2006 | 11:14 PM
Are the Driver+Passenger Air Vents removable for painting?
Pics coming up this weekend.
Old Sep 7, 2006 | 02:31 AM
djfrestyl's Avatar
Suspension Yoda
Yes, they're removable.
Old Sep 7, 2006 | 07:28 AM
Great!
Ill get to painting those too.
Old Sep 11, 2006 | 12:28 AM
UPDATE :
Parts painted :
HU trim
AC Vents
Door handle trim front/rear
Map Light unit
Coin holders
Front/rear window switches
mirror switch trim
Glove department handle
Gauge trim
Could've done a better job if i hadnt rushed it.
Final conclusion :
Ended up with a cool looking interior. All my friends are going crazy over it, asking me 100's of Q's.
Bose unit cd player doesnt feed after the paint job, god knows why...
Thats about it.
Old Sep 11, 2006 | 05:11 PM
MAN that is a bright silver. Good job, dude.
Old Sep 21, 2006 | 04:49 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
All you need to do now is fix the e brake boot... and slap some polish on all the black. Especially the steering wheel. Good job though man... it came out really nice.
Old Sep 21, 2006 | 08:14 PM
djfrestyl's Avatar
Suspension Yoda
What head unit is that?
Old Sep 24, 2006 | 02:23 PM
stock Bose?
Cd got fudged over though when i removed it. Doesnt want to eat the CD's.
Old Sep 24, 2006 | 03:38 PM
djfrestyl's Avatar
Suspension Yoda
That doesn't look like the Bose units I've seen before.
Old Oct 8, 2006 | 06:45 PM
Yea, i saw another version of the 4th gen Bose Unit too. Confused me.
But im guessing they made 2 styles.
Old Oct 11, 2006 | 10:24 PM
VIP Maxima
i have been thinkin about this vs purchasing a dash kit.
i just want to know if there is any paint that doesnt have those sparkling metalic stuff in it. just a FLAT paint + clear coat. any ideas? IMO the sparkles make it look cheap. i want OEM-ish finish
Old Nov 10, 2006 | 06:52 PM
What do you guys think about painting the Driver/Passenger speaker covers Silver?
Mine either have paint peeling or some type of white drink on on them because it looks like its chipping.
I might just re-paint them black.
Opinions.
Old Nov 10, 2006 | 07:00 PM
djfrestyl's Avatar
Suspension Yoda
Keep them black.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
gavin68
Sep 18, 2021 12:36 PM
Apr 16, 2020 05:15 AM
Luigi623
Sep 21, 2015 01:42 PM
