Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Painting the wiper arms
Old Sep 4, 2006 | 07:39 PM
sunten1
Hi
My 4th gen's wiper arm paint is starting to come off and exposing the bare metal behind it. I want to paint them black again.
So:
1. What paint should I use?
2. Where can I buy this paint
3. Do I have to sand down the wiper?
Sunny
Old Sep 4, 2006 | 08:04 PM
matty's Avatar
Any type of black spray paint. Krylon or Rustolym
Home Depot, Walmart, Local Auto parts store, Hardware store
I would. Make a nice surface for the paint.
-matt
Old Sep 4, 2006 | 08:17 PM
sunten1
Ok, so if I sand it down will the paint stick properly to the metal behind it or do I have to put down a primer on the arms?
Old Sep 4, 2006 | 08:21 PM
matty's Avatar
You can primer it if you want. Doesnt really matter.
-matt
Old Sep 5, 2006 | 06:15 AM
wikidminds's Avatar
i did not sand or primer. i just sprayed on a flat black spray pain by krylon and it looks like new. just cover the surrounding areas of ur car. IE:hood and windsheild to prevent overspray if u do not remove the arms from the car.
Old Sep 5, 2006 | 08:25 AM
matty's Avatar
Just take the arms off
Old Sep 5, 2006 | 12:59 PM
sunten1
How do I do that?
Old Sep 7, 2006 | 07:36 PM
nadir_s's Avatar
vicodin ... gift of life
good tips guys ... will do that this weekend. mine's been faded for a very long time now.
Old Sep 7, 2006 | 07:54 PM
Eyemfaster's Avatar
taking them off is much safer than trying to mask the other stuff off.
Old Sep 7, 2006 | 08:24 PM
matty's Avatar
How do I do that?
Old Bolt on each Arm.
-matt
Old Sep 19, 2006 | 01:12 AM
Orgullo's Avatar
$$ Ballin on a Budget $$
First off I have to disagree about not taking care of the prep work first. If you want a good finish that is going to last then you need to prep it first.
Take them off by taking that little cap off the base of the wiper. It's easier to get to if the hood is open. When you take off that cap you'll see the nut that holds it in place. Press down on the wiper arm to flatten it out and remove the nut and wiggle it up and off.
Sand it completely down with light sand paper to get a smooth feel.
Rustolm Metals paint is good. They have both primers and paints.
Lay the primer and you'll see where you missed with your sanding. Even out and respray with the primer. After it is dry you can paint it out to the color of your choice.
If you don't prep your going to end up doing it again in the long run.
If you want to paint the vent panel here is the pic for that too. It shows you how to take it off. This is for my 5.5 so I'm not sure if it's exactly the same. However, it shouldn't be too different. Let me know if you need anything else.
The red squars are just "plugged in." All you have to do is gently pull up on it. The arrows point to little black pins that you can remove with a flat headscrew driver. The one on the drivers side is a small phillips head screw. The part that rest on the glass and acts like a gasket can be taken off too. Just make sure you've got some glue to put it back on after you get done painting it. DON'T PAINT IT WITH IT ON THERE. One it will look like azz, two it has to rest back on the glass to prevent water from going in between.
Old Oct 3, 2006 | 05:24 AM
95mtlMAXSE's Avatar
shift_Puff
i got mine powder coated semi gloss black and I DID sand them before i brought them to paint
Old Oct 3, 2006 | 06:46 AM
MaximaSE96's Avatar
Maxima Owner
yea i painted mine once...then after winter they started to chip agian...so i stripped them and powdercoated them....i love having a powdercoater
Old Oct 3, 2006 | 04:56 PM
nadir_s's Avatar
yes!
i did this over th weekened. literally took me 15 min to do and they came out awesome.
I just took em off (easy to take off) and did a quick sanding and painted it w/ a matt black paint can that I had.
It dried in about 15 min and i slapped em ack on. they look new!
pics comin
REDinLV
Aug 15, 2024 12:30 AM
Apr 16, 2020 05:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
leatherneck
Sep 30, 2015 09:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
