Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
$50 Paintjob FTW?
Old Feb 26, 2007 | 03:53 PM
gtr_rider's Avatar
$50 Paintjob FTW?
http://www.rickwrench.com/50dollarpaint.html
Amazing result
Old Feb 27, 2007 | 08:52 AM
clayman88's Avatar
That is amazing that he was able to get that kind of a result for so little money. I wonder how long the finish will last though.
Old Feb 27, 2007 | 10:12 AM
LA02MAX's Avatar
repost, but still worth mentioning. I would definitely hit that up if I had a beater car...
clayman: One of the people that used it has had his for 2 years with no sign of fading. Pretty impressive if you ask me.
Old Feb 27, 2007 | 04:00 PM
MDeezy's Avatar
extremely impressive.
Old Feb 27, 2007 | 04:11 PM
mikey chalupa's Avatar
That is very interesting. If I had another ride besides the Max I would give it a try.
Old Feb 27, 2007 | 04:27 PM
LA02MAX's Avatar
http://board.moparts.org/ubbthreads/...0&fpart=1&vc=1
here's another link with some more results.
Old Feb 27, 2007 | 07:23 PM
MetaOrbit's Avatar
Got Projectors?
Heheheh...I actually used this very method to paint my refrigerator from white to black when I moved into my new house (all black appliances).
Granted, a refrigerator's a little bit easier than a car, but it looks great. Most people never notice. I have to tell them I painted it.
Old Feb 27, 2007 | 10:54 PM
Alex_V
I'll be painting the 240sx (its primer red :/) this spring with rustoleum and maybe even the maxima. The paint is pretty scratched/beat on the maxima but they are both 1990's. It should turn out pretty good, and I do want to get the maxima painted next year. Its black so it should turn out pretty good.
Im thinking blue or something for the 240sx, and the maxima is black so it's staying black. I'll definitely post lots of pics.
~Alex
Old Feb 28, 2007 | 06:20 PM
Matt93SE's Avatar
STFU n00b!
time is money.
how many hours (days) did this guy spend sanding and buffing on the car as compared to the cost of a properly applied quality automotive paint?
PPG White, about $60 a gallon. blue, about $20/qt, clear $150/gal. lacquer thinner, $20/gal. Air compressor $350 (you'll already have one if you're doing resto/maintenance work of this caliber)
paint gun, $75
so that's $325 for quality automotive paint and a paint gun.
rust-oleum is about $60 a gallon. rollers, trays, cleaning equipment, let's guesstimate around $40. add in the additional case of 600 and 1000 grit sandpaper you'll be about $125 in materials.
considering only the change in paint and the labor associated with it, you're going to spend 1-2 days painting using conventional methods, and a week using the rustoleum.. so you're looking at 5 days difference. assume 8 hr days working on it (sanding, buffing, masking, painting, etc).. that's 40 hours of additional work to apply the paint with a roller.
So let's look at the time factor of money. my time doing something else in my driveway is worth $35/hr. That's $1400 in labor.
So you're subtracting $200 in materials but adding $1400 in labor to be able to roll on paint that's not designed for this application instead of to spray the proper automotive paint and not have to worry about it.
Old Feb 28, 2007 | 06:38 PM
4x4Max's Avatar
paint gun, $75
wait a minute....only 325? i was under the impression that paint is a lot more expensive than that.
Old Feb 28, 2007 | 06:49 PM
LA02MAX's Avatar
time is money.
paint gun, $75
well when the time comes for me to get a project car, I'll actually enjoy doing things like this, so I guess it's up to the buyer.
Old Feb 28, 2007 | 06:51 PM
Matt93SE's Avatar
STFU n00b!
depends on what color you want.
Chevy's Torch Red (what I'll be painting the Maxima with) is about $450 per gallon in the cheapest stuff I can find. Keep in mind though that red is the most expensive color out there, period. (discounting pearls and chromalusion paints)
Nissan Arctic White (Kelly's 97 Altima) was like $17 a quart and under $60 per gallon.
You can pick more basic off-the-shelf colors that don't require custom mixes and save a lot of money. you just have to shop around a bit and see what you can get. (Going with Rust-Oleum, you're only getting to choose a few colors anyway, so you'd got an infinitely better selection going to automotive paints)
Old Feb 28, 2007 | 06:55 PM
Matt93SE's Avatar
STFU n00b!
I still enjoy working on mine too, but when it comes to bodywork and getting the car painted, I'd rather sand and buff it only once, not 10 times. if you've never wet-sanded an entire car, you'll only want to do it once, trust me. it's a 6-8 hour job to properly wet-sand an entire car with 1000 grit- especially when you're using a paint that's been roller-applied and has a ton of orange peel. Imagine doing that after every coat of paint....
my bad shoulder is screaming just thinking about it.
Old Mar 1, 2007 | 05:53 AM
MacGarnicle's Avatar
I'm very impressed as well - finish looks great. Any thoughts on if the job is worth it? I'm not sure how long a paintjob like this would last? LA02MAX says there is someone who did this and it has lasted 2 years now - is that 2 years of DD, or 2 years of 75% in the garage?
Obviously this method doens't allow for 'long-term' results like a factory paintjob would, but I'm still interested if it would last long enough on a dd car for it to be worth it.
40 hours of labour is a LOT of time - still, must feel good knowing that money you would have spent at the paint shop, is still in your pocket.
Old Mar 8, 2007 | 02:25 PM
KeithD's Avatar
This looks like a great way to paint an old beater jeep or winter beater or something to that effect, but as Matt said, way way too much work for the result. Make friends with someone with a compressor and you'll be much happier. As he said, if you've never wet-sanded a car before, you don't know what you're getting yourself into..
Old Mar 8, 2007 | 02:39 PM
LA02MAX's Avatar
Originally Posted by 69chargeryeehaa
I used this technique on my 1974 beetle also, here are the results:
http://i32.photobucket.com/albums/d1.../Picture10.jpg
the car before:
http://i32.photobucket.com/albums/d1...n/IM000475.jpg
another after pic:
http://i32.photobucket.com/albums/d1...n/DSC00164.jpg
here is a car i sprayed (71 beetle, midnight blue metalic):
http://i32.photobucket.com/albums/d1...n/DSC00194.jpg
here is the car before (71 beetle):
http://i32.photobucket.com/albums/d1...n/Picture1.jpg
here's a few pics of the charger done:
http://i32.photobucket.com/albums/d1...n/DSC02764.jpg
http://i32.photobucket.com/albums/d1...n/DSC02769.jpg
well that's my 2 cents worth, sorry for the long post. i was borred lol
i painted the orange beetle in 1999, and it still looks like the day i painted it, the 71 blue beetle i painted in 2000, and built the car for my dad, i used the same paint on my charger, maybe one day i'll spring for a good paint job, prepping is 90% of the work, stripping the car, sanding, ect.....painting is overrated!!!
So if you have TIME, then i'd say go for it, the worst that could happen is that it does'nt turn out and your out $50, but if your paitient, and expriement with lets say just the trunk pannel and if you like it do the whole car, if not just get it done by someone else for $4000. i don't know about you guys, but i would rather spend the $4000 on other parts like getting the mechanics sorted out and new chrome, cause when u have really nice paint and crappy bumpers, door handles it just sticks out more.
MacGarnicle this guy has had his for nearly 7 years! (at the time this post was created) That's a pretty decent amount of time. I'm not sure whether these cars are daily driven or not...I'm guessing the charger is not, but the beetle might be....this is from the link I posted above.
Old Mar 8, 2007 | 06:52 PM
wow, that's very impressive- thanks for pointing that out
Old Mar 17, 2007 | 06:51 PM
5thgenmaxima's Avatar
I'm Glad I found this thread. I have an 89 mustang I'm getting ready to sell that I just put over $2000.00 into. AS-IS I wouldn't be able to get $500 out of it. (unless I parted it out, then I'd probably get $1000 out of it) It's already been sanded and "prepped" for paint, but finding someone to do it is a problem. Seems like this may be a good car to practice on. Maybe I'll do 4-5 coats then wet sand, then do another 1-2 coats and wet sand after the 6th and 7th coat. Anyone see a problem with short cutting to save time and not wet sanding after every coat?
Old Mar 18, 2007 | 07:20 PM
Matt93SE's Avatar
STFU n00b!
problem there is that the paint layers won't stick to each other, so the paint starts peeling shortly after you finish the car. not cool.
Old Mar 24, 2007 | 01:21 PM
Well, I bought the paint and have applied my first coat on one fender as a test ..
So far it looks like ****..
Old Mar 24, 2007 | 01:56 PM
LA02MAX's Avatar
What was prep like?
Old Mar 26, 2007 | 06:01 PM
What was prep like?
Sure you wanna go there? Body work FTL. I sanded the clear coat and all grime off the car until it was smooth. Then I cut out the rest and welded in new sheet metal. Finally, I added body filler (yea, I mean bondo) to the welded sections to even the surfaces out. After a few dozen more hours of getting the sections filled with bondo smooth and level I noticed I missed a few spots sanding. What did I do you ask??
I removed the fenders and paid an in-law $7.00 an hour to finish the prep work. (F.Y.I. He doesn't ask if I need any side or yard work done anymore.)
So, I start to paint the car. There are no runs, but there are to many air bubbles in the paint. I'm going to sand the first coat down with 300 grit since the paint is to bubbly and thin the next coat out a bit more. I'm at about 50/50 right now. We'll see how it turns out.
Old Apr 14, 2007 | 08:35 PM
supamonkey's Avatar
mean! if i had the ***** to do that to my car i would
tifosiv122
22
Feb 4, 2002 08:29 AM
ereet
Mar 28, 2001 08:16 PM
