Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
I <3 Meguiar's PlastX
Old Jun 9, 2007 | 09:05 AM
flxsunxchick's Avatar
USF Class of 2009
My boyfriend and I decided to purchase a bottle of Meguiar's PlastX to try to remove the haze and nastyness from our headlights - he has a 95 Jeep Grand Cherokee Orvis and I have a 2000 Nissan Maxima SE. Let me say that I love this stuff. I thought that I would have to purchase an entirely new set of headlights or pry the old ones apart to clean the inside, but a four dollar fix was exactly what I needed. I recommend it.
Before
After
Old Jun 9, 2007 | 09:14 AM
wikidminds's Avatar
lot better than before...
Old Jun 9, 2007 | 03:27 PM
99BlackMaxMS's Avatar
Didn't do the best for me...I am now considering wetsanding.
Old Jun 11, 2007 | 03:29 AM
Bluesbrekr's Avatar
Doctorate in Detailing
They look much better...good job.
The key is in the application. Using a PC with Plastix or Novus and a 4 inch pad works really well.
Old Jun 20, 2007 | 12:16 PM
Infinity-KSK's Avatar
I still dont feel confortable doing this myslef. Im afraid ill messing something up.
Old Jun 20, 2007 | 03:00 PM
USF Class of 2009
It wasn't hard at all. I used a 4 in" pad and applied the PlastX in a circular motion. It says to start with a small area at a time. I did about two or three layers and wiped off the excess with a soft cloth. It's similar to waxing your car, except no muscle is required to remove the extra stuff. You can get great results doing it manually, but I'm betting using a buffer would make it come out twice as nice.
Old Jun 21, 2007 | 05:12 PM
wirelessdude04's Avatar
yea I wet sanded with 600 grit then 1000 then 2000 then finished off with my PC and some Plast-X saved me about $150+
Old Jul 24, 2007 | 06:34 AM
d4ster3's Avatar
I tried this PlastX and it didnt really work for me... my headlights look more hazy now than they did before... all I had to wet sand with was 800 grit... do you think I can clear it up if I get some 1000, 1500, and 2000 grit and then use the PlastX???
Old Jul 24, 2007 | 08:21 AM
MOHFpro90's Avatar
800 is far to coarse for this(without stepping up). I used 2000 only to clear up mine. Use soapy water also, works better.
Old Jul 24, 2007 | 10:02 AM
VIP Maxima
wetsand it from brand new look !
Old Jul 24, 2007 | 12:09 PM
d4ster3's Avatar
I did wetsand it.......... I picked up the CV Headlight Restorer/Defogger today from WalMart that was talked about in another post, its got 1000 and 2500 grit plus cleaner and sealer so I think ill try it tonight
Old Jul 24, 2007 | 02:19 PM
skidz88's Avatar
For best results: Spray your headlight with soapy water and then use 800, 1000, 1500, 2000 grit sandpaper. Finish it off with Plast-X applied with a Mothers Powerball.
Mine look brand new now.
Old Jul 24, 2007 | 07:10 PM
MOHFpro90's Avatar
Got it exactly right, (same concept) except I used scratchX instead of PlasticX(all I had). Also, I didnt use a powerball, just some elbow grease, no need to buy one if you dont have one.
Old Jul 24, 2007 | 07:53 PM
96blkonblkse's Avatar
flxsunxchick lol your sig is funny.
"A girl who drives stick? Now that's hot..."
i say that all the time..now if she drives a maxima thats even better
Old Jul 31, 2007 | 10:45 AM
cbr_rachie's Avatar
yeh the plastix stuff worked really well for my headlights too....check it out...
Old Jul 31, 2007 | 12:02 PM
mannetti21's Avatar
Do you let this stuff dry after applying, and then wipe it off? Back of the bottle doesn't mention the drying part but otherwise I dont see how this is gonna work.
Old Jul 31, 2007 | 03:27 PM
USF Class of 2009
96blk: Yes, my boyfriend thinks it's hot I drive a stick
cbr: You did a great job - your lights look great.
mHOVA: I didn't let mine dry completely, if I remember. Don't treat it like a wax, more like a cleanser. I applied and removed excess a few times, then again my lights were HORRIBLE.
Old Jul 31, 2007 | 04:04 PM
mannetti21's Avatar
I just tried this on my foglights since I swapped to Silverstars. It made a very slight difference, so then I turned a 15min job into a 2 hour project and sanded them.
I'll make a post in a bit with pics before Plastx, after plastx, and after sanding and plastx.
LouE37
21
Apr 28, 2003 04:14 AM
BlancMax
Mar 26, 2002 06:15 PM
luvmymax
Oct 22, 2001 09:44 AM
Johnson
Nov 25, 2000 06:17 AM
