Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Cleaning headliner
Old Feb 13, 2008 | 02:45 PM
Reket's Avatar
Cleaning headliner
I had a stain on my headliner so I sprayed some carpet cleaner on it and began to brush it but when it dried the area is now darker than the rest of the headliner? any suggestions?
Old Feb 14, 2008 | 07:54 AM
PrinzII's Avatar
OG and counting...
Never spray directly onto the headliner. Spray the cleaner on a towel and lightly agitate the area you are trying to clean.
Old Feb 17, 2008 | 05:48 PM
Reket's Avatar
Yes...hindsight is 20/20 but is there any way to fix this
Old Feb 17, 2008 | 09:49 PM
SuperStasiu's Avatar
Oxy clean in a bucket of warm water with a micro fiber towel worked the best for me cleaned hole headliner, maybe try cleaning the hole headliner like that
Old Feb 17, 2008 | 11:03 PM
96blkonblkse's Avatar
depending on what car(trade in) if i am cleaning it to get whole saled or whatever ill just use brake cleaner. spray it on a clean towel and wipe the affected are and it works good!
I personally havent used it in my car yet but ive used it on several cars with good results. Never had any fading issues. Ive even used it on the hard plastic..like the door sills, just make sure you use a conditioner after though.
Old Feb 23, 2008 | 08:10 PM
00MaximaGXE's Avatar
Seriously Brake cleaner on a headliner? I think I've heard it all. I would use a 10/90 of Woolite and Water then use a rag and ever so lightly rub it on the liner. basically think if it this way your headliner is held on by glue and if you soak the affected area later down the line your headliner is going to start sagging
Old Sep 19, 2008 | 07:48 AM
ZGadson's Avatar
I tried to clean a spot on mine with some carpet cleaner. Just turned the gray spot black. How safe is it to use brake cleaner on the headliner? Supposedly it works (as was said above) but will this have a negative effect on the glue holding up the liner?
Old Sep 21, 2008 | 02:36 PM
B_Eaze's Avatar
not sure about brake cleaner, only one way to find out.
I used woolite diluted 8:1. I sprayed that directly on the headliner w/o issues and used microfiber cloths... but i suggest spraying onto cloth first
Old Sep 24, 2008 | 09:11 AM
jaywills1020's Avatar
if one spot is darker then the rest of it just do the entire thing and everything should match
Apr 16, 2020 05:15 AM
jonreidhead
Jan 6, 2016 09:38 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
