removed by dealer badge from my car because I was sick of looking at it and the little bastard thing left a nice brow adhesive oval in the back of my car
anyone have an idea how to get rid of that crap it looks disgusting.
Goo Gone... (rubbing alcohol works too, but takes more time) it's what I used and worked great. After that I used some light rubbing compund and then polished with a buffer... history
its the left over glue or tape. Take a blow dryer adnset it on hot and fast blow.. what ever its called. Get some rubbing alchohol too. Heat the adhesive and rub with the rubbing alchohol. Like BJS said it will take time but it will come off . After your done ust wax that area and you done.
I've used 3m adhesive/wax remover. Be sure that after you use any of that stuff, rewax the area to seal things back up.
S
S
A lil heat and goo gone= clean surface. Or you can just wait it out and it will slowly get out after a while lol.
I say put a little heat and some goo gone..its gonna take a little time and some real hard rubbing and after its all gone or most of it, get some wax and wax the area and it should be good, one of the most aggrivating jobs of the max is debadging and getting the goo off!!
Quote:
S
+1 on the 3m, that stuff works great for decals or tape. I've removed both.Originally Posted by maximase86
I've used 3m adhesive/wax remover. Be sure that after you use any of that stuff, rewax the area to seal things back up.S
Quote:
You're exactly right, this is a great product to keep in the arsenal.Originally Posted by fishforlife2007
i personaly would reccomend Bug and Tar Remover. its made by turtle wax. stuff works wonders
For that sticky adhesive just keep on heating it up and pealing it off little by little with either your thumbnail or a cloth.
Quote:
Maybe a bit late into the thread but I would never use rubbing alcohol to remove anything from a car. That stuff will eat right through your clearcoat. Get some bug and tar remover or a similar product; I would never risk an improvised, home-made fixer on my paint especially when there's any sort of hard rubbing involved.Originally Posted by maxgen5
Get some bug and tar remover, smear it over and rub it lightly. Not too hard, or you may hurt the clearcoat. If the car is a couple of years old there will be some color-fade (the paint under the sticker will be like new, basically). Apply some Meguiars' ScratchX or a similar product following the directions on the bottle and then give the car a fresh coat of wax. Shouldn't notice the difference, unless the car is really old.
i've used wd-40 because i had it laying around and it worked just fine. just make sure to rinse it off when you're done.
Very true, alcohol can be a bad thing if used carelessly. This should have been noted as well as the weak rubbing alcohol variety.Originally Posted by Maximillionaire
Maybe a bit late into the thread but I would never use rubbing alcohol to remove anything from a car. That stuff will eat right through your clearcoat. Get some bug and tar remover or a similar product; I would never risk an improvised, home-made fixer on my paint especially when there's any sort of hard rubbing involved.Get some bug and tar remover, smear it over and rub it lightly. Not too hard, or you may hurt the clearcoat. If the car is a couple of years old there will be some color-fade (the paint under the sticker will be like new, basically). Apply some Meguiars' ScratchX or a similar product following the directions on the bottle and then give the car a fresh coat of wax. Shouldn't notice the difference, unless the car is really old.
The old detailer's trick is a hair dryer to remove the emblem and at the same time,it is softens the adhesive.
The gas trick works great little at a time on a rag and the stuff is gone. Just make sure you throw a coat of wax on after, save's the clear coat!
Has anyone asked the dealer to remove it before leaving the lot? I think I'm going to do that when I buy a car. They stuck it on, they can take it off. Maybe that will teach them not to put their advertisements on our cars.
Some fishing line, a hair dryer, and Goo Gone. But as everyone else has said, make sure you treat the paint appropriately afterward.
I used a rubbing compound from Meguiar's. Love Meguiar's.
for goo-gone and tar remover.
