Started the detail on the Max
Well, I recently picked up a 2001 sherwood green Maxima SE, it's very clean and has 112k on it but I don't believe that it was ever detailed before. Definitely looks like it was a frequent attendee of car washes though. I just kicked off this project and I'm hoping to finally get a detail documented start to finish....so here goes
Before:
After:
Before:
After:
I know, I know. I might try to start back up on it Friday. I tried a little today, but thumb was having no part of the buffer. Hopefully another day and the swelling will gone and it can take the vibration. I'll definitely get it going again by the weekend.
Optimum Compound - orange pad
Optimum Polish - white pad
Red Moose Machine Glaze - grey pad
Poorboys EX-P sealant - grey pad
Red Moose 100% pure Carnuba wax - blue pad
I might switch to a yellow pad with the compound to get some additional cut because it took a good amount of work to get the scratches out and the whole car is like the first picture. There's also some spots on the passenger side that I'll need to wet sand and buff too. I should probably take some pics of that too.
Random orbital buffer.
Is that Porter a buffer? But yes I'm gonna use a RO.
Same principle, but the PC has a little more power and has some additional flexibility with changing pads and such. I believe the one you have probably has a fixed foam pad that you tie the bonnet too? That's what I started with and just slowly worked up.
See I don't want more power, I'm afraid I'll burn or damage the paint. But your right about the foam pad and bonnet.
With the PC, you can't burn the paint since it's still an orbital polisher, not a rotary. You could sit there and crank on the edge of the paint and not burn it. You would really have to go out of your way to mess up, either not paying attention to your pad being clean or draging the cord across the paint. It's definitely great for a novice or someone just getting started. Easy to use and great results.
You can also check youtube for videos of people using it.
Yeah, the joys of winter. I was using the snow blower to clean the driveway and my thumb fell out of joint again. Now I've got to have it immobile for a while. This blows.
ah2002
Mar 9, 2016 01:42 PM
FlaMark
25
Aug 28, 2015 10:15 AM
jholley
Aug 11, 2015 09:38 AM
Team STILLEN
Aug 10, 2015 04:29 PM
