Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Water spots on windows
Old Jul 5, 2010 | 09:34 AM
Shift_Nashville's Avatar
So my wife drove my car while I was gone for a while, washed it a bunch, and didn't know that she couldn't just let it air dry ...So now I have waterspots on all my windows and I couldn't get them off...I've read on the "Net" about different solutions, but we all know what happens when you listen to untrusted sources from the internet {you pour sand in your intake manifold}...So I want to know what people here have done to rid themselves of those pesky spots...I tried a couple times with no luck, but I was only using common cleaners...I've heard about Vinegar, using 0000 steel wool, and things like glass science scrub {also heard that ****s up windows}...anyways, what are your experiences getting rid of waterspots???
Old Jul 5, 2010 | 10:58 AM
phatboislim's Avatar
have you tried simply waxing the windows yet?
Old Jul 5, 2010 | 11:23 AM
No...I don't know too much about detailing...
I heard of alot of things to try, but this is the first regarding waxing your windows...maybe you could enlighten me?
Old Jul 5, 2010 | 11:38 AM
Definitely wax your windows. That's what I do and it works everytime. I use a spray wax for the windows though.
Old Jul 5, 2010 | 05:09 PM
shadyonedeath's Avatar
i used steel wool but it leaves very fine scratches, not noticeable unless at night under a street light and your looking for them.
Old Jul 6, 2010 | 02:28 AM
Do you remember what weight you used? I've heard that 0000 won't scratch...
Old Jul 6, 2010 | 07:01 AM
Stalldaworld's Avatar
clay bar
Old Jul 6, 2010 | 04:51 PM
000 and 0000 is the same ****.
I used car wash soap/water in a spray bottle to prevent anything major.
Old Jul 6, 2010 | 04:55 PM
RAZ76's Avatar
Claybar all your windows and then wax. Not only will it remove teh spots but all your side windows will roll down so much easier. Mothers sells a good clay bar kit.
Old Jul 7, 2010 | 09:06 AM
thanks for the info guys...I'll see what I can do...
Old Jul 7, 2010 | 07:20 PM
back2basics's Avatar
I have a polish that is specifically designed for removing spots from glass, it works great and leaves a nice smooth finish, unless the spots are from "acid rain" in which it is actually etched into the glass and can not usually be removed.
It's called Duragloss Nu-glass and you can still find it.
I found it locally but here is a link.
http://www.amazon.com/Duragloss-Car-.../dp/B0007IJR1I
Old Jul 9, 2010 | 04:45 PM
VTonmymind's Avatar
Mmm, fresh lobster
take a peek in the best glass cleaner/pesky water spots a few threads down from yours.
Old Jul 10, 2010 | 12:17 PM
threebetyou's Avatar
Just try really good glass cleaner. My gf did the same thing I had some Armorall glass cleaner just scrubbed it good, dried it with a towel and it was fixed
Old Jul 11, 2010 | 09:02 AM
...oops...I looked QUICKLY, but didn't see it...I only get a couple minutes of internet time every few days...
Thanks though
Old Jul 12, 2010 | 11:44 AM
tigersharkdude's Avatar
I can help you out
Old Jul 12, 2010 | 12:11 PM
dan.worts's Avatar
definitely try a glass cleaner and elbow grease first, then try a polish if that doesn't work, then go clay bar imo
Old Jul 12, 2010 | 11:42 PM
jcrome04's Avatar
Chrome/Glass polish
Old Aug 2, 2010 | 07:31 AM
DimaK's Avatar
wax. or all purpose cleaner(very mild one)
Old Aug 2, 2010 | 07:42 AM
GM_Traitor3.5VQ's Avatar
Clay bar with some Mother's Showtime quick detailer worked quite well for me. If they are REALLY bad spots, try some Zaino Z-12 Glass Polish http://www.zainostore.com/Merchant2/...oduct_Count=14
This stuff works magic, especially if your car has a few years on it. Restores the clarity of all your windows.
Old Aug 11, 2010 | 12:51 PM
ColdRain's Avatar
by no means to hijack this thread, but you mind enlighting us with acid rain statement? Reason why im asking is, because long time ago i used rubbing alochol or acetone(cant remember) to take tree sap off the window. Now, tree sap is gone, but the spot that was sprayed shows very bad. Its clear, but its visible like water spot.
Old Aug 14, 2010 | 01:20 PM
saylee's Avatar
i work for nissan/toyota and whenever we have customer vehicles that request for water spot removal, we use savage acid and dilute it with soap and the water spots come right off but you have to be careful because if your vehicle is to warm/hot, youll burn your paint. It works awesome on windows, another alternative is using really fine steel wool with no thick steel in it, i think its the finest thinnest version of steel wool, you can pick up a box from home depot and Steel Wool works really good on windows. If the water spots aren't deep, i recommend Steel Wool because it'll do the job. (just make sure that you apply at least 5-6 sprays of window cleaner because if you dont, it can scratch your windows. hope that helps
Old May 15, 2011 | 07:02 AM
Khamisalminawi's Avatar
imma try that out
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
