Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
best/ strongest wheel cleaner
Old Jun 2, 2011 | 04:14 PM
maxspeed96CT's Avatar
The original VQ...
I need something that will get rid of all that junk on the inside of the wheel not just the outside.
My plan is to remove the rims and clean them all around, It seems like if I clean the face, all the nasty black tar/gunk from the inside just works its way right out.
any suggestions?
I previously tried the off the shelf wheel cleaners and simple green . Neither really worked like I hoped.
Old Jun 3, 2011 | 07:54 AM
tigersharkdude's Avatar
Try this stuff its really good. But without seeing some pictures of the damage I cant really say if it will work or not
Sonax Full Effect wheel cleaner
Old Jun 4, 2011 | 06:04 PM
The original VQ...
thanks, do any of the local parts stores sell it that you know of or is it just online?
Old Jun 4, 2011 | 07:11 PM
If you find it local, let me know.....
Best price I know of
http://www.autogeek.net/sonax-wheel-cleaner.html
Old Jun 4, 2011 | 11:26 PM
maxima801's Avatar
^^THIS.... I will have to get...I just dont want to damage my wheels...Thanks
Old Jun 5, 2011 | 03:23 PM
coolsun's Avatar
Look up the Brown Royal wheel cleaner on YouTube, I use it n its great! Comparing to all the wheel cleaners in stores
Old Jun 5, 2011 | 04:14 PM
QT1 5MT AE's Avatar
Gram Lights addict
never use anything more than soap and water to clean your wheels. some of these are acid based and ruin the finish. id use a steam cleaner !
Old Jun 5, 2011 | 04:30 PM
The original VQ...
ya that works great on the outside, but I have these tiny spots on the outside of the rim from my brakes.
And the inside of the wheel is just filthy, and it seems like that dirt just works its way out as soon as it clean the outside of the rims.
Old Jun 5, 2011 | 04:38 PM
BLKonBLK98's Avatar
what type of finish are the wheels? for painted barrels i usually use brake cleaner, scotch bright pads/microfiber towels, and a power washer.
Old Jun 5, 2011 | 06:52 PM
ray_289's Avatar
Pre soak with a good mixture of all purpose cleaner and hit it with a power washer if you have one...if not pre soak...spray again and go to town with decent sponge...works for me ...Meguiars hot wheels cleaner (red or purple bottle i forget) has done the job in the past but it's easier for me to mix some all purpose.
Old Jun 14, 2011 | 05:24 AM
95maxrider's Avatar
Lightly modded
It sounds like you have some axle grease stuck to the inside of your wheels because normal brake dust doesn't act like the way you're describing it. You need to get the bulk of it off with a paper towel or something before you waste your time with cleaners. I recently bought some P21S wheel cleaner gel since I've always liked gel wheel cleaners, but haven't used it yet.
Old Jun 14, 2011 | 05:28 AM
phatboislim's Avatar
generally...if i'm pulling my wheels to clean them outside and out...i use purple power and dish detergent and also spray teh wheel with purple power wash it and rinse it off and work on the next wheel.
Old Jul 20, 2011 | 11:55 AM
myaeger18's Avatar
Meg's makes a great product called Wheel Brightener. You cannot buy it in the store. It is part of their pro line. You buy it by the gallon and dilute it. If you go that route make sure to buy a chemical resistant sprayer. That stuff can be abrasive. Also, when I use it I wear rubber gloves. I know, it sounds too strong. It's not overly strong, but you'd be surprised what it can do. Sonax is great, but very $$$.
Old Aug 12, 2011 | 08:35 AM
vr4z06gt's Avatar
I've had good luck using just bug and tar remover. Supposedly it won't harm the clear coat on the wheels but it removes just about everything. I have just sprayed the entire wheel and allowed it to penetrate for about 5 minutes. Then using a kitchen scrubbing brush, like the one for dishes (not to stiff to scratch but hard enough to actually do something) just give them a a good scrubbing. You can try this and maybe a mr clean magic eraser, those things remove alot of crap. Just don't forget to wax the wheel and use a wheel sealant afterwards. There are plenty out there that minimize stuff sticking to the wheel for a while after you wash it.
Old Aug 13, 2011 | 10:59 AM
wirelessdude04's Avatar
yup steam cleaner works best with some sort of a degreaser. Purple power works well cut down
Old Aug 13, 2011 | 05:45 PM
Big Tyme's Avatar
I agree with the Sonax being the best. Could also try Iron-X and Tarminator. Tarminator they sell at most auto parts stores so it should be easy to find. All these products are safe for wheels. Iron-X and Tarminator can even be used on the paint as long as it is wet prior to application. Let the products dwell for awhile then hit with a wheel brush and rinse. Repeat as needed. Once you have them clean don't forget to seal the wheel. Good luck!
Old Aug 13, 2011 | 09:58 PM
Ejay98max's Avatar
Bacon Grease!!!
Old Aug 14, 2011 | 06:57 AM
Originally Posted by Ejay98max
Bacon Grease!!!
Random post to bump your post count, that wont fly around here
Old Aug 15, 2011 | 08:49 AM
NABU6's Avatar
I use Poorboy's World Bio-Degradable All Purpose degreaser. Works very well, and you can dilute it to fit your needs. Use the same product to clean my engine bay, and i use diluted version for a house hold cleaner (bath tube, kitchen sink, etc) very versatile product. You can by it by the from Autogeek.net. http://www.autogeek.net/pbapc128.html
Old Dec 16, 2011 | 03:52 PM
myaeger18's Avatar
+1
This stuff is amazing! Dont let it dry on your wheels and use it in a well ventilated area. Its very strong smelling. I also use latex gloves with it.
Old Feb 5, 2012 | 11:55 PM
Arsen's Avatar
Heavy duty stove cleaner does wonders!
HOKUSMAX
Nov 13, 2017 04:34 AM
Fbana41
Aug 29, 2016 12:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
