Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Another headlight thread
Old Sep 1, 2011 | 10:54 AM
macnolias's Avatar
Just wondering if it's advisable to wet sand and follow up with http://shop.advanceautoparts.com/web...6_T|GRP2050___
Just an idea I've been jogging.
Old Sep 1, 2011 | 11:03 AM
5th gen dd's Avatar
This is common practice with MR2 tail lights. Just make sure you keep the sand paper extremely clean while working. It's very easy to make deep scratches in the plastic. However, whether or not it can stand up to the heat from the headlights I cannot comment on.
Old Sep 1, 2011 | 11:41 AM
macnolias's Avatar
ouch the heat is right. headlights basically just have a clear coat that wears over time then the oxidation starts, correct? Instead of polishing every month I'm trying to think of a more permanent solution.
Old Sep 2, 2011 | 12:21 PM
5th gen dd's Avatar
That's correct. The housings will have a coating on them from the factory. I ran a detail shop for ten years. Probably one of my least favorite things to do was wet sanding headlights in an attempt to blend the peel line from the clear coat.
Looking back on it I do remember someone offering the option to wet sand and clearcoat headlights. The majority of the work I saw done looked like crap though. A ton of fish eyes. Probably just a result of poor prep work. We would normally just wet sand and polish them with a rotary buffer but like you that only lasts so long.
I just picked up my 3rd Max, a 5th gen, that has faded headlights. If I don't pick up a set of retrofits first I may try this myself.
Old Sep 10, 2011 | 06:40 PM
wirelessdude04's Avatar
I did mine today wetsanded them and them buffed them with a attachment for my drill and used plastic X ill post pics up tommorow
Old Sep 10, 2011 | 07:20 PM
Why not try wheel clear by either Duplicolor or Rustoleum? That has to withstand some sort of heat.
Old Sep 12, 2011 | 08:23 AM
Flava_24/7's Avatar
Boosted Panda
Or just a clear engine enamel. It should adhere to plastic just fine.
Old Sep 12, 2011 | 10:03 AM
Either or should work. Engine enamel probably withstands heat much better.
Old Oct 22, 2011 | 10:57 PM
District's Avatar
Check out this thread.
http://forums.maxima.org/detailing/5...ning-pics.html
Apparently, Brasso, cleans the headlights pretty nicely, making them look almost brand new. I assume, they apply a wax after the Brasso cleaning, but I am not sure. If anybody knows, do reply.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Noela
Sep 26, 2015 08:22 AM
