Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
How do you remove old tint?
Old Aug 5, 2013 | 02:44 PM
hungy82's Avatar
Hey there folks, Im wanting to retint my windows on my 2K max, but I cant afford to have the old removed and the new installed, so I was curious to see if there was a cheap, easy, non-messy way to remove the original tint....somebody told me a steamer would work, is this true? thanks
Old Aug 5, 2013 | 03:07 PM
Amerikaner83's Avatar
easiest way I found, though I've never done it:
http://www.tacomaworld.com/forum/det...heap-easy.html
Old Aug 6, 2013 | 04:57 PM
Youtube it. Lots of good videos and tips. You'll find the preferred method of removal is with trash bags and ammonia, or with a steamer.
Ptatohed and I removed his tint a few months back with the ammonia method, worked like a charm.
Old Aug 21, 2013 | 04:35 AM
Drag0n97's Avatar
I just sprayed mine and used a blade to scrape it off it came right off u just gotta keep it wet
Old Mar 13, 2014 | 07:21 AM
Patm-a32's Avatar
Depends what window... If rear windsheild BE CAREFUL u can easily mess up ur defroster lines. I let the defroster heat up the window for a few minuets then took a razor blade to a corner and all peeled off in one peice... If the adhesive is left behind dont worry... Goo gone should get it off. But if it is to strong and goo gone doesnt work (happened to me) go to a store and get a bottle of rubbing alcohol, put on rag or paper towel and stuff works like magic...
Old Aug 13, 2014 | 06:22 PM
viprider's Avatar
Shampoo in a spray bottle and gently scrape it with a blade. You can also use wd40 for tough adhesive.
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
