Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Here is my weak dyno
Old Feb 18, 2003 | 03:31 PM
1SikMax's Avatar
http://www.1sikmax.streetracing.org/photo3.html
Old Feb 18, 2003 | 03:56 PM
UMD_MaxSE's Avatar
Got Bent?
what car?
auto, manual?
any mods?
Old Feb 19, 2003 | 12:14 PM
1SikMax's Avatar
Originally posted by UMD_MaxSE
what car?
auto, manual?
any mods?
I have a 99 Maxima 5 speed with a K&N drop in. And it's a Cali spec engine.
Old Feb 19, 2003 | 06:13 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Continuing from...
http://forums.maxima.org/showthread....hreadid=188007
Any updates on that CEL / coil pack issue?
Also check tire pressures, filter cleanliness, and fuel. What mileage are you at and have all the services been done to it? Your torque is right where it should be, but for some reason it's just falling off a bit more than normal in the top-end with your horsepower numbers.
Old Feb 20, 2003 | 12:09 PM
1SikMax's Avatar
Originally posted by SteVTEC
Continuing from...
Yeah, my car is getting worst. I saw that the CEL started blinking so I parked the car and gonna trouble shoot it soon. I need to replace that coil pack. It keeps cutting on and off.
Old Feb 24, 2003 | 12:41 AM
Dev's Avatar
Dev
could you tell me the symptoms of a coil pack that needs replacing?
while i was racing, i heard a bang, which caused engine hiccups.
i get these engine hiccups in first and second gear at low rpms <2500.
i don't have any engine codes (0505) so im wondering if i have fouled spark plugs?
btw...your car dyno numbers look kind of low...but could that be the result of cali-spec emmissions?
Old Feb 24, 2003 | 11:47 AM
1SikMax's Avatar
Well, when my car gets like that it , just like you say, hiccups. It's pretty much to me kinda like a cylinder not firing. Really weak no power till higher RPMs then it kinda smooths out. Yeah, sometimes my when Im flooring it, it will jerk hard then starts the "hiccups." I'll tell you a way that I found out if I had a bad one. Other than getting a 0201 or the opposite, I forgot, ecu code. When my car started acting up. I went out with a screw diver and started disconnecting coil packs one at a time while the car was running. If it was good ofcourse the car would run crappier. If it was bad nothing would happen. Well, good luck I hope I was somewhat of help.
Old Feb 24, 2003 | 03:48 PM
Dev's Avatar
Dev
yes that did help...thank you
i was really worried when i heard that "bang" when i was racing, since my car was running perfectly prior to that.
im going to have my coils tested this weekend with a multimeter, but if that doesn't work...ill be sure to try your disconnection method.
thanks for your help
Old Feb 25, 2003 | 11:05 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
I had a '92 S/C'ed Bonneville that had the exact same problem. Thought I was throwing a damn rod the first time it happened, but I figured it had to be ignition related. Same exact description as what I've read here.
Old Feb 25, 2003 | 01:57 PM
Dev's Avatar
Dev
was the problem solved by replacing spark plugs?
Old Oct 26, 2004 | 01:45 PM
Zack342's Avatar
that's what we do. it sucks being a 99 cali spec
Old Oct 28, 2004 | 06:59 AM
XoPtOn's Avatar
I wish i knew my maxima was a cali then i wouldnt have bought it lol
Old Oct 28, 2004 | 05:26 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
cali is no problem to get rid of get a non calis engine harness and ecu and there you go no more cali. Also change a few components. my 99 cali is now 95 fed spec swapped from auto too 6 spd.
Old Oct 31, 2004 | 10:36 PM
Supermax95's Avatar
so, what is/are the difference(s) between a cali spec and fed spec maxima? and hoe do i know which mine is?(dont mean to hijack)
Old Nov 2, 2004 | 04:54 AM
tedo007's Avatar
faster than you think
its in the 4th gen FAQs check it out
Old Nov 3, 2004 | 12:10 PM
roofadoofalus's Avatar
not too shabby
Ben2003GLE
31
Jul 17, 2016 08:13 AM
spencerwh1
Jun 30, 2016 05:44 AM
Balkins
Feb 1, 2016 12:45 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
MikesChevelle
Aug 9, 2015 11:50 AM
