Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Dyno'd today. About right!
Old Aug 24, 2003 | 09:28 AM
d_warner's Avatar
Old Timer
Well, I dyno'd the max today. It's a 1997 GXE 5-speed with 93,000 miles. I've got an intake, y-pipe, and test pipe. I did three runs and the results are as follows.
Run 1: HP = 178.6 (peak @ 5200 RPM)
TQ = 183.9 (peak @ 4700 RPM)
Run 2: HP = 175.6 (peak @ 5200 RPM)
TQ = 183.0 (peak @ 4700 RPM)
Run 3: HP = 175.7 (peak @ 5200 RPM)
TQ = 180.4 (peak @ 4700 RPM)
These number are about what I expected, but I was hoping to see closer to 190 at the wheels. Oh well. I'm still pleased. The curves are extremely smooth from 2000 to 3500 RPM, but then a slight fluctuation kicks in. THe dyno operator said I might need new plugs. Can anyone tell me if that sounds right?
DAvid
Old Aug 25, 2003 | 03:02 PM
maximamaybe's Avatar
Good numbers David. I had my 2002 Maxima dynoed today.
My best run was 209.1 HP/229.1 Torque
Graph
Old Aug 27, 2003 | 08:43 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Re: Dyno'd today. About right!
DAvid
I/Y/E on a 4th gen 5spd will not typically get you 190 whp. I think your numbers are more or less on target. To get 190 whp you need some more mods (UDP would help). If you want more top-end, the MEVI will definitely help you out in that department, although you still might not get 190 whp.
Old Aug 28, 2003 | 06:54 AM
maxger's Avatar
Graph
Why is there such a dip at 4000 rpm in torgue and HP?
Old Aug 28, 2003 | 08:49 AM
SteVTEC's Avatar
Variable intake manifold switchover.
Most cars with a variable intake manifold that I've seen dynos for (IS300, BMW 3-series, Acura CL-S, Camry V-6, etc) all have similar dips due to manifold profile switchover points. Depends on the design, though.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
keensali
Sep 23, 2015 08:59 PM
f.matejaiii
Sep 21, 2015 12:09 PM
wingnut2006
Sep 19, 2015 06:13 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
