Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
204whp, 198tq - 1996 SE manual
Old Feb 24, 2004 | 05:58 PM
96sleeper's Avatar
Mods:
JWT hybrid intake
70mm TB
MEVI
cattman ss y-pipe
test pipe
2.5 b-pipe
hooker muffler
JWT ecu
UR underdrive pulley
Stock clutch/flywheel
graph shows my previous dyno as an automatic (with faulty rpm switch on the MEVI), and then after the 5spd swap.
Old Feb 26, 2004 | 10:30 PM
j_bryan's Avatar
Originally Posted by 96sleeper
Mods:
JWT hybrid intake
70mm TB
MEVI
cattman ss y-pipe
test pipe
2.5 b-pipe
hooker muffler
JWT ecu
nice numbers! I have a 96 also. How much for the 70 mm TB (ported right)? Did this help much in terms of HP?
Old Feb 27, 2004 | 09:02 PM
MAXimumHP's Avatar
Nice numbers man! Must be nice to have the cardomain sig covering up your 7000rpm redline
Wonder what kind of gains you would get from the JWT cams...
Old Feb 28, 2004 | 06:32 PM
j_bryan's Avatar
I'm also curious why you went w/ 2.5 exhaust piping rather than 2.25. I thought that 2.25 was good enough for NA.
Old Feb 28, 2004 | 08:27 PM
Nealoc187's Avatar
SLOW
Most aftermarket exhausts are 2.5"... generally only the cheaper ones are 2.25".
Old Feb 29, 2004 | 10:57 AM
audiyoudo
nice numbers! is that a wheel dyno or chassis dyno (ie. did you have to take your wheels off to dyno your car or just "drive-on"?)
Old Feb 29, 2004 | 11:00 AM
michaelnyden's Avatar
what rpm is your rpm switch on your mevi set at?
Old Feb 29, 2004 | 02:08 PM
nismo2020's Avatar
Needs non-Maxima Friends
absolutley amazing .. that ecu+vi+70mm tb works wonders.
Old Feb 29, 2004 | 06:53 PM
96sleeper's Avatar
is it a standard in-ground dynojet (248 I think) and it is SAE corrected.
Old Feb 29, 2004 | 06:56 PM
96sleeper's Avatar
I have the summit switch so it is set at a weird rpm, I don't remember what it is. I just adjusted it on the dyno until there was no dip in power. The engagement point seems to be 5300 rpm.
Old Mar 5, 2004 | 04:00 PM
speedemn's Avatar
Mods:
JWT hybrid intake
70mm TB
MEVI
cattman ss y-pipe
test pipe
2.5 b-pipe
hooker muffler
JWT ecu
Excellent numbers!!! This has got to be the highest NA MEVI'd numbers out of a gen 4 Maxima!
Do you know what the temperature and humidity were at the time? The dyno graph should show it if you have it on disk. What is the Correction Factor?
Have you done any 1/4 mile passes with this setup or before?
Old Mar 5, 2004 | 04:41 PM
96sleeper's Avatar
I don't know the temp but it was a little warm that day. I believe the correction factor was 1.01, so not very much. I went to the track alot as an automatic tranny, but not yet with the 5spd.
Old Mar 7, 2004 | 12:16 PM
j_bryan's Avatar
is the 70 mm tb is from a pathfinder? What year pathfinder did you use that fits a 4th gen?
Old Mar 7, 2004 | 01:09 PM
speedemn's Avatar
I believe that the 2001 Pathfinder 3.5 has the compatible 70mm TB.
Old Mar 7, 2004 | 08:40 PM
96sleeper's Avatar
none of them fit a 4th gen. The TB is from a 2001 pathfinder, you have to make an adapter plate to make it work.
Old Mar 8, 2004 | 05:53 PM
Dave B's Avatar
Not DAVEB the parts guy
Yep, he has the highest numbers. Requin6 (Paul) dynoed his 96 SE with the MEVI/JWT ECU/intake/y-pipe/UDP and pulled 200fwhp/198fwtq. Not bad I must say.
Dave
Old Mar 8, 2004 | 05:57 PM
speedemn's Avatar
Dave
I dynoed 190/190 with the mods you mentioned above minus JWT ECU. The ECU is in now though and I will be dynoing in the spring! I really hope mine can turn out that well too!!!
Edit... oh wait, I got b-pipe and flywheel too.
Old Mar 18, 2004 | 10:44 AM
nismology's Avatar
Nope. Iron Lung made over 210WHP with the STOCK redline.
Sweet numbers nonetheless
Old Mar 18, 2004 | 11:02 AM
Jeff92se's Avatar
I'm needing a caw
Great numbers! Your pulling bigger numbers at the wheel than the rated flywheel numbers!
TB. What did you have to do for the TPS and the other various vacuum connections?
Old Mar 24, 2004 | 03:43 AM
96sleeper's Avatar
TPS is the same, I just calibrated it to the maxima values per the haynes manual. I removed the fast idle cam/cold start from the TB and just bypassed the vacuum connection on the bottom.
The extended redline has nothing to do with more power, the peak power occurs before the stock redline anyway. It just provides more area under the curve. It is not just peak numbers that show how fast a car is, it is the area under the curve. I posted a comparison between me and iron lung's dynos that is pretty interesting. The torque of the ecu sure is nice, I wish there was one for the 99's so he could see what numbers he pulls. I am trying to decide whether or not I want cams or FI.
Old Mar 25, 2004 | 02:07 PM
nismology's Avatar
The only reason I said that is because with his setup the raised rev-limiter ITSELF will automatically up his peak HP output seeing that his HP peak is at redline and still rising. We're not discussing area under the curve or what car is faster or not. Who cares? This is in the dyno forum, not the 1/4 mile forum. Besides I already understand that area under the curve is what matters.
Just stated that his HP #'s are the highest (in response to the post i quoted) and will get even higher once an ECU becomes an option for him.
Much props to you though...
my03maxima
Jul 28, 2024 07:40 AM
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
