Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
176hp - 184 tq
Old Nov 1, 2004 | 01:28 PM
|Bijan|'s Avatar
UCF Lexus
176hp - 184 tq
98 gxe manual
Ran in 3rd gear due to speed limiter cutting off at 115mph in 4th gear
visit homepage for mods
Old Nov 2, 2004 | 04:50 AM
tedo007's Avatar
faster than you think
why dont you cut the wire so you can remove the speed limiter
Old Nov 2, 2004 | 07:39 AM
|Bijan|'s Avatar
UCF Lexus
I need to, not a lot of free time
Old Nov 2, 2004 | 08:38 AM
mzmtg's Avatar
Minister of Silly Walks
3rd gear
-56743
Old Nov 4, 2004 | 07:36 AM
cardana24's Avatar
Blown
what is so bad about dynoing in 3rd gear? I ask because this is the gear I usually dyno in....will the dyno be in accurate?...the guys at the shop told me that the difference in 3rd and 4th would only be several hp....and 3rd is a shorter pull/lower mph
Old Nov 4, 2004 | 08:56 AM
NmexMAX's Avatar
dot dot dot ...
I believe it has to be the gear closest to 1:1 ratio. Autos dyno in 3rd.
Old Nov 4, 2004 | 09:09 AM
cardana24's Avatar
Blown
I do know that...but what does that really mean? As far as putting power down? Is third inaccurate for that reason?
Old Nov 4, 2004 | 08:13 PM
|Bijan|'s Avatar
UCF Lexus
3rd isnt INACCURATE persay.......but since it's NOT 1:1 ratio....it wont be the exact same as 4th gear.
Old Nov 5, 2004 | 09:22 PM
DAVE Sz's Avatar
Hooooooonda.....
Aren't the numbers a bit low there Bijan?
Old Nov 6, 2004 | 06:09 AM
|Bijan|'s Avatar
UCF Lexus
no
Old Nov 6, 2004 | 12:47 PM
DAVE Sz's Avatar
Hooooooonda.....
They seem low to me.
Old Nov 6, 2004 | 01:07 PM
|Bijan|'s Avatar
UCF Lexus
Well then edit them for me
Old Nov 12, 2004 | 11:30 PM
AsthmaMax11's Avatar
Bijan,
I put similar #'s down with almost the same mods. I actually feel better after seeing that a similar 4th gen 5 speed dynoed close to my #'s. However, I believe 96sleeper dynoed something like 204 HP and 201 tq at this same dyno with only a few more mods....
Old Nov 27, 2004 | 10:04 AM
Broaner's Avatar
2060lbs and falling...
Many sources say that dyno'ing in a 1:1 gear is sorta cheating. It reduces friction and extrapolates the power numbers to be ones that are only available in that gear. Every other gear encounters more friction and therefore makes less WHP/WTQ. IMO, real WHP/WTQ should be measured in 3rd.
heresmymind
Nov 5, 2007 12:11 AM
elcid
42
Jul 27, 2002 07:08 AM
speedracer3
May 22, 2001 03:16 PM
