Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
94 Nissan Altima Dyno vid
Old Oct 30, 2005 | 12:21 PM
Import Roller's Avatar
Vid 217whp 204ft lbs
I gotta get the G's Vid edited so its not so lengthy, but the G put down 244RWHP
Old Oct 30, 2005 | 12:53 PM
Zack342's Avatar
Bit off topic.....
Old Oct 30, 2005 | 05:47 PM
its not off topic. this is a section for Dynos right? so i posted my vid of my car on the dyno. I know its not a maxima, but still, its a nissan
Old Oct 31, 2005 | 06:25 AM
Zack342's Avatar
List mods for both cars please....
Old Oct 31, 2005 | 09:28 AM
G35 Stock
Altima (too much ****, but the main stuff is)
OBX 4-2-1 header
clogged cat
custom catback
CAI
Apex-i S-AFC II Tuned
75 shot NOS Wet kit
MSD SS Blaster Coil
MSD 6+ controller
10.2mm wires
NGK 7 series plugs
Nismo Adjustable FPR
Fuel Pressure gauge
Walbro 255lph pump
and some other misc ****
Old Oct 31, 2005 | 09:34 AM
NmexMAX's Avatar
dot dot dot ...
Do you have the run files?
Old Oct 31, 2005 | 11:10 AM
Zack342's Avatar
Originally Posted by Nissan Love
G35 Stock
OBX 4-2-1 header
clogged cat
custom catback
CAI
75 shot NOS Wet kit
MSD SS Blaster Coil
MSD 6+ controller
10.2mm wires
NGK 7 series plugs
Fuel Pressure gauge
Walbro 255lph pump
Damn i thought for sure your altima was turbo with those #'s. what does it lay down off juice?
Old Oct 31, 2005 | 02:17 PM
niceguy's Avatar
Haha...as a Max/Altima owner I can tell you w/i a few hp....1st gen Altimas put down a mere 111/125whp stock (auto/manual) and with bolt ons, autos put down ~140whp (I/H/E), more w/tuning, cams,etc...and manuals in the 150-160whp range depending on extent of mods...My '93 auto Altima dynoed 111whp/130tq stock and 144whp/150ishtq w/intake/header and Max muffler.
Most of the turbo Altimas running on the forum put down mid-high 200s, with a few running around 300-320ish whp(running 12.7s 1/4mile) and one or two close to 400whp w/built engines....
Sorry for the OT but you wanted info ...
Old Oct 31, 2005 | 03:56 PM
my car off juice puts down 136whp. that was with a clogged cat (still clogged), so im guessing once it frees up, i will be around 140whp. I should be turboed soon if things work out correctly. I never ran this car on a dyno when it was stock, so i dont know what it would have made at that time
Old Oct 31, 2005 | 03:57 PM
are you talking about the dyno charts? I do, but I havent scanned them yet, so i cant post them online.
Old Oct 31, 2005 | 04:14 PM
NmexMAX's Avatar
dot dot dot ...
Run files, you should be able to get them from the shop you dynod at... I'd be interested in the G35 files.
run files are better than a chart posted...
Old Oct 31, 2005 | 05:06 PM
Zack342's Avatar
I have my brothers 2003 six speed G35 dyno run files but what is odd is his only did 240whp.
You have one strong auto.His trapped 97mph at the track though.
Old Oct 31, 2005 | 06:33 PM
are you talking about the A/F file where it tells you your RPMs and mixture readings down in columns per 100rpms? if so, I have it for my altima, but not the G
Old Nov 1, 2005 | 06:47 AM
NmexMAX's Avatar
dot dot dot ...
Run files let you look at any data incrememnt captured (RPM/SPeed/HP/TQ/AF in very small or very large increments) all with relation to speed/time/rpm.
But the file let's you do it at your own discretion ....
Old Nov 1, 2005 | 09:18 AM
then i dont have it
Old Nov 1, 2005 | 09:50 AM
NmexMAX's Avatar
dot dot dot ...
nothing named dynorunfile.001 type of files on disk?
Old Nov 1, 2005 | 11:20 PM
didnt get a disc, just a print out
Old Nov 2, 2005 | 07:37 AM
NmexMAX's Avatar
dot dot dot ...
Might want to ask them for the files via email or some other REM(removable electronic media)
Old Dec 1, 2005 | 09:46 AM
Brushedpewter's Avatar
Where the hell is the torque???
you got 217whp and 204ft lbs????
You should have 230-260ft lbs.
Bowzer, erebuni, what's his face( the guy with the wrapped CAI that live in miami and got 14.8), they all got more than 220ft lbs and some of them have 30whp less than you.
Old Dec 1, 2005 | 11:11 AM
NmexMAX's Avatar
dot dot dot ...
260, are you smoking anything your employer should know about?
Old Dec 1, 2005 | 08:14 PM
maybe 230 would be better, my car had put down 235ft lbs when i was on a dry shot, but a dry shot is more violent when it engages, and the wet kit is more evenly mixed for a smoother hike.
Old Dec 2, 2005 | 11:07 AM
NmexMAX's Avatar
dot dot dot ...
We were referring to the G35, since it has much more maxima relation than your spraying alti
Old Dec 2, 2005 | 01:22 PM
tavarish's Avatar
fwd gone rwd cr00
what were you doing in that G35 to make it run a 15.2?
Old Dec 2, 2005 | 08:49 PM
The G put down over 240ftlbs, the altima has the low torque for some reason. But i think it was because of low nitrous pressure.
and the G running low 15s was mostly due to the heat on the track. most cars were running between .5-1 sec slower than normal. some even a lil over a second
Old Dec 20, 2005 | 11:35 AM
streetzlegend's Avatar
Well I just dynoed and i got the same hp as the alti but my torque was higher. i did 217whp and 240tq. maybe its because of different engine, oh and it was also a wet 50 shot.
Old Dec 20, 2005 | 11:48 AM
NmexMAX's Avatar
dot dot dot ...
Ya think
and 240tq.
STD
SAE = 234
Old Dec 20, 2005 | 12:15 PM
i mentioned the difference of engine because he posted that it was due to low pressure.
Old Jan 23, 2006 | 09:54 PM
I've had TQ ratings prior in the 250ftlbs range, but that was with everything at full strength. I hope to dyno again soon after i fix some issues i have with my bottle heater and see what i put down then. My guess is somewhere between 220-230whp, and 240-260ftlbs
MaxLife17
Sep 8, 2015 02:36 PM
jfl330
Sep 4, 2015 01:44 PM
DrVee
Sep 4, 2015 12:18 PM
coasterswim
Sep 2, 2015 07:43 AM
