Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
vq35 17 deg. timing advance gains....
Old Jan 1, 2006 | 10:58 PM
MxdOut97's Avatar
looking to find out the gains from advancing the timing to 17 degrees on my 5.5 gen vq35, anyone have some rough numbers or dyno sheets? thanks
Old Jan 2, 2006 | 07:48 AM
NYPD-Arnold's Avatar
Z
Someone posted this in the Other Cars section, but it wasn't done a Maxima VQ35, though. Regardless, the gain was minimal...a difference of 3WHP which could've just been attributed to a difference in conditions outside. Plus, timing advance seems to be pretty ho-hum on VQ35s. It's especially punchy and noticeable on VQ30DE-Ks only.
Old Jan 2, 2006 | 08:20 AM
MxdOut97's Avatar
yea thats what i heard, but expected a little more than 3 whp, oh well. thanks arnold
Old Jan 2, 2006 | 01:27 PM
NmexMAX's Avatar
dot dot dot ...
Who knows, I have a dyno w/ GAB and a separate one with POP intake and 17* .. but who knows what the difference is when changing from GAB --> POP.
So...it's not really a good comparison.
Old Jan 2, 2006 | 03:32 PM
nismology's Avatar
The timing advance won't add any peak power because it's not in effect after around 2300 RPM.
Old Jan 2, 2006 | 03:39 PM
L0R1DA's Avatar
That seems to be the common consensus. I would imagine timing advance to only be a way to regain some of that low-end that mysteriously tapers off after certain mods (exhaust, and some intakes).
Old Jan 2, 2006 | 04:07 PM
MaxObesset's Avatar
how do you advance the timing i have a 4.5 gen and would like to advance my timing alittle bit
Old Jan 2, 2006 | 04:10 PM
LA02MAX's Avatar
consult II at your local nissan dealer; they can charge you anywhere from $0-$150 ($150 being what they were going to charge me )
Old Jan 2, 2006 | 04:11 PM
nismology's Avatar
You need a 2000 and up ECU to be able to do this. The options that availiable to 4G's are JWT ECU, TS, ECU, piggyback such as SMT-6/7 and/or e-manage ultimate, or you can advance your timing indirectly via a S-AFCI-II/V-AFCI-II
Old Jan 2, 2006 | 04:14 PM
LA02MAX's Avatar
whoop, true that...as you can tell, i hang out in the 5th gen forums a little too much
Old Jan 2, 2006 | 05:34 PM
NmexMAX's Avatar
dot dot dot ...
No one listens to me
Old Jan 2, 2006 | 07:02 PM
steven88's Avatar
Need A Light?
wasn't your previous best like 222whp? then after the 17* n popcharger, you went up to 233whp?
Old Jan 2, 2006 | 09:09 PM
Puppetmaster's Avatar
With bigger injectors and a FPR.
Just wanted to complete that statement.
Old Jan 2, 2006 | 09:16 PM
steven88's Avatar
Need A Light?
leaning out = advance timing
richen out = retard timing
Old Jan 3, 2006 | 06:45 AM
nismology's Avatar
Well in this case it's bigger injectors OR FPR since you only need one of them to increase fuel flow.
Old Jan 3, 2006 | 06:46 AM
nismology's Avatar
Yes.
Old Jan 3, 2006 | 06:52 AM
Thanks for the clarification.
Old Jan 3, 2006 | 08:41 AM
NmexMAX's Avatar
dot dot dot ...
219 Vs 233
Old Jan 3, 2006 | 07:22 PM
steven88's Avatar
Need A Light?
219 Vs 233
wow thats a pretty big gain...14whp from only a 17* and popcharger....
i wonder what gains you'd get from open air filter
Old Jan 3, 2006 | 07:31 PM
NmexMAX's Avatar
dot dot dot ...
open air filter
Mine has a bunch of holes in it
Old Jan 4, 2006 | 08:59 AM
vipervadim's Avatar
I like Maximas
I bet the headers helped too
Old Jan 4, 2006 | 09:32 AM
NmexMAX's Avatar
dot dot dot ...
Actually,
I had headers both times, only thing changed was the POP and 17*
Old Jan 4, 2006 | 02:14 PM
HotshotVQ35's Avatar
219 WITH headers? i did 218 with a ypipe!
219 Vs 233
Old Jan 4, 2006 | 02:17 PM
michaelnyden's Avatar
so popcharger and timing advance 14whp wow..! I can't imagine if you would get some real timing advance put in!
Old Jan 4, 2006 | 03:09 PM
MaxObesset's Avatar
i have a vafc2 i have an aem fpr in the trunk gonna install it soon i was thinking of getting an jwt ecu and bigger injectors soon
Old Jan 4, 2006 | 03:30 PM
nismology's Avatar
219 Vs 233
It's impossible for timing advance to increase peak numbers since it doesn't change the timing above 2300 RPM. And we all know about intakes so i'm as to how there's such a large gap between the two dyno's.
Old Jan 4, 2006 | 07:36 PM
maybe the conditions on the day of the dyno were way different...
were you using a different octane fuel? new air filter, spark plugs, fuel filter, etc.?
Old Jan 4, 2006 | 09:09 PM
NmexMAX's Avatar
dot dot dot ...
Hmm, typically y-pipes add 8-12whp on an A33B.. so that would put you at one of, if not the highest stock #'s on here..
Also, comparing our dynos, you're 6MT, and I'm auto ... also, I only got 211 w/headers only. ... But Still outpower you 6K+ .:IBpissingcontest:.
Yup, still puzzles me to this day. What's amazing is the area under the curve that's added. Check this forum, all my dynos are scattered in a few threads.
I gained 9 from GAB ( same day/hour) but I'm still not saying the POP/GAB is Gods gift, only that it does show a difference, whether GAB or POP.
Days were similar. I can send you the run files. Everything's the same except for the tests being done on different days(important factor), and what has been mentioned (POP & 17*).
Old Jan 4, 2006 | 09:19 PM
steven88's Avatar
Need A Light?
But you're 6MT, and I'm auto ... also, I only got 211 w/headers only. ... But Still outpower you 6K+ .:IBpissingcontest:.
hey i was wondering if you could send me the run files for all your dynos?
steven88@mindspring.com
thanks manny!
Old Jan 4, 2006 | 09:27 PM
NmexMAX's Avatar
dot dot dot ...
No prob...
When are you going to get on the rollers?
Old Jan 4, 2006 | 11:31 PM
steven88's Avatar
Need A Light?
No prob...
not for awhile....i still gotta get the car fixed...thats my first priority...then after that, install the vafcii...then find an opening at the dyno shop...
Old Jan 5, 2006 | 07:08 AM
NmexMAX's Avatar
dot dot dot ...
Old Jan 5, 2006 | 03:00 PM
not meant to be a pissing contest at all.AMGE55 or whatever his name is said he gained 33WHP from headers alone. i dont know if he was 6spd or auto. but i dont know why you only got 211 with only headers, i seen dynos, yes 6spds with intake that did that. so i dunno i need to get my HS headers on and Vafc-II in and see whats up...
Old Jan 5, 2006 | 03:05 PM
NmexMAX's Avatar
dot dot dot ...
I'm only being a selfish dynowhore/Queen
Invalid Post, DO NOT BRING MODERATOR INTO THIS DISCUSSION
Old Jan 5, 2006 | 03:07 PM
:attention
Old Jan 5, 2006 | 03:12 PM
NmexMAX's Avatar
dot dot dot ...
My car must've been extra that day..
I'm sure it's over its ess now ...
Old Jan 5, 2006 | 03:15 PM
nope your car was stickers dont add HP
Old Jan 5, 2006 | 03:19 PM
NmexMAX's Avatar
dot dot dot ...
Then my pop charger added 22 whp ... since I dynoed 211 w/ stock intake, and 233 w/ POP.
Old Jan 5, 2006 | 03:48 PM
and people said intakes dont gain any HP!
Old Jan 5, 2006 | 03:56 PM
NmexMAX's Avatar
dot dot dot ...
They don't
