vq35 17 deg. timing advance gains....
I have a question, if advancing timing only adds anything below 2300 rpms, then why are all those who have done the 3.5 swap so concerned with advancing timing on their engines?
Damn, I gotta dyno my car already.....especially before I go boost this spring
......but I think I should be putting down atleast 240whp with intake,custom 2.5" exhaust(no res, no cats),headers,jet chip ecu(BS), 17*, ur udp....I think if I had a vafc I would be putting a little more because my car runs too effin rich, backfiring all over the place. But I should be putting up a dyno sheet real soon.....
Are you taking bets
[QUOTE=NmexMAX]The timing you're referring to(and this thread as well) and the timing they're (JClaw) referring to is different.QUOTE]
Please elaborate, I didn't know that there is multiple kinds of timing. What is the difference between the 2?
Dealer 17* = Base timing.
JClaw = wants to advance ignition timing thru powerband
A33B = CVTC, cam timing on Intake cam
Originally Posted by NmexMAX
Cam timing, iginition timing, base iginition timing
Even the JWT ECU doesn't run as much timing as a stock 2k2 does.
Tilley, with basically the same car as me, put down 233whp. But he has a JWT ECU and had the A/F tuned through SAFC-II. I have neither. So I was maybe at 220whp/220wtq when I ran my 13.3.
Dunno but he said he had an SAFC-II. Maybe he was using the stock ECU at the time...
Anywho, to get back to the subject, you wont see much from a 1-2 degree advance.
I don't remember who, but someone advanced timing 8 degrees on a 3.0 and gained something like 12whp/10wtq throughout the powerband. He said we could probably get +15 degrees over stock 3.0 ECU timing with a VQ35.
And we have 94 Octane readily available 'round here...
I have NO doubt that the car would be faster with your ECU, especially if the track was hot and soaked with VHT (that means 1.75-1.80 60 foots with slicks).
But yeah I'm a crazy canuck...
A little slice-of-life...
Last September me and Jime (nice guy by the way) met at a Quebec-vs-Ontario event at a local dragstrip of mine.
Towards the end of qualification he offered to temporarily install his OBDII scanner in my car for a run to see what I'm reading for timing during the run (Also, interestingly, my idle is actually 1334-1340 rpms based on his scanner, even though it appears to be somewhere between 1400 and 1500 on the actual tach).
Anywho, unless it's the crack, I remember the scanner varying a lot between 13 and 23 degrees during the run (hard to say really, when you have to shift 3 times during the run).
On that day the car was particularly slow, trapping around 100 mph. On the very next day I realized my knock sensor bolt was alarmingly loose and tightened it good.
The trap speeds were hovering between 103.8 and 105.3 all Sunday long, vs the constant 99-100 mph traps from Saturday.
True story. And I have NO idea what to make of it.
Originally Posted by nismology
That's a rumor that i may have had a hand in spreading. Jime has has logged his timing at WOT in his A33B and the his numbers were similar (~17-18* BTDC) to his stock A32 ECU. Not saying this is typical, but just throwing something out there.
How did he tune the A/F using JWT's static maps..
Just thought I'd offer geez..
this might be off topic a little bit, but is it possible at all to adjust A/F with a JWT ecu?
Starrider
Sep 17, 2015 07:26 AM
and customs are
