Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
low numbers why??? 16.3hp 182.99tq on a 2001 auto w/ mods
Old Jan 4, 2006 | 12:51 PM
tjrocks's Avatar
low numbers why??? 163.3hp 182.99tq on a 2001 auto on 18"s
mods are cattman cali spec y pipe, injen cai, ground wires, safc 2, RT high flow cat, custom catback, UR udp, timing advance
looks like vias is opening but it stops at 5500rpm why ??
anything else that could give me low numbers ??
could it be because of the 18"s that are about 50 w/ tires ??
pls any input will be helpfull
Old Jan 4, 2006 | 01:03 PM
NmexMAX's Avatar
dot dot dot ...
Your VI is What did you tune for with the SAFC?
Gnd wires, high flow cats, Injen CAI are snake oil IMO
Do you have the runfiles?
Old Jan 4, 2006 | 01:06 PM
s0ber's Avatar
Dooooo you have runfiles? If not could you scan a closer picture or something..
Old Jan 4, 2006 | 01:21 PM
Kevlo911's Avatar
Kevlo for President
VI is broken or almost broken.
Old Jan 4, 2006 | 01:32 PM
tjrocks's Avatar
cant really get better pictures but blue is #2, red # 4 and green#7, i tuned the afr to about 13.5 on the last run. thanks for the input. I will take apart my vias tonight. oh yea i almost forgot i also have a timing advanced to 17
Old Jan 4, 2006 | 01:53 PM
NmexMAX's Avatar
dot dot dot ...
What was the correction factor (off of my own curiousty)
Old Jan 4, 2006 | 01:56 PM
tjrocks's Avatar
according to printout CF: SAE smoothing: 5
Old Jan 4, 2006 | 04:09 PM
s0ber's Avatar
Yeah im with them, your VI is def prolly broken... JB Weld Mod !
Old Jan 4, 2006 | 07:42 PM
tjrocks's Avatar
just did the jb weld mod, hope it works.
Old Jan 4, 2006 | 07:46 PM
s0ber's Avatar
was your vias cup loose?
Old Jan 4, 2006 | 09:16 PM
NmexMAX's Avatar
dot dot dot ...
Not the smoothing The actual correction factor ... i.e 1.01, .98 SAE
Old Jan 5, 2006 | 12:30 PM
tjrocks's Avatar
not exactly sure what cf is then, anyway when i checked my vias it was loose, but not anymore after jb weld. I'll just have to get it dynoed again to see if the fix worked.
Old Jan 5, 2006 | 12:42 PM
NmexMAX's Avatar
dot dot dot ...
Look at the run condition details (in different colors).. on the sheet
Old Jan 5, 2006 | 01:56 PM
wperdigon's Avatar
why don't you tune it down to a 13.1? you could have a better setup with that - at least i laid out 191whp with my sentra on a 13.1 afr
Old Jan 5, 2006 | 02:12 PM
NmexMAX's Avatar
dot dot dot ...
I bet it wont make up for his broken VIAS.
Old Jan 6, 2006 | 05:04 PM
tjrocks's Avatar
ill try that.
Old Jan 28, 2006 | 06:57 PM
tjrocks's Avatar
finally fixed vias, got 179 hp and 183 tq ill post some pics of the dyno when i find my camera.
Old Jan 29, 2006 | 02:11 PM
NmexMAX's Avatar
dot dot dot ...
Sweet...
Did you get the run files by chance?
9aj9
Apr 5, 2020 12:11 AM
GregL65
Sep 7, 2015 10:33 PM
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
mikebla
Sep 3, 2015 05:37 PM
