Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Dyno seems a bit low?
Old May 27, 2006 | 11:36 AM
NAS's Avatar
NAS
Went today and here are the results, seems a bit low to me...
91 shell gas
Short Intake
Budget Y
OBX cat back
NGK 1 step colder plugs
164.3 hp@5600
168.4 tq@4000
NX wet 50 shot, no heater, I dont know bottle pressure...
207.3 hp@5400
215.1 tq@3900
Old May 27, 2006 | 12:18 PM
Kevlo911's Avatar
Kevlo for President
Dead Knock Sensor?
Old May 27, 2006 | 02:07 PM
NAS's Avatar
NAS
more info.... car has 52400 miles, temp was 70-80?, car was running rich mostly around 11.3 w/out n2o, 10.3ish with n20, and I believe the runs were done in 2nd gear, if any of this helps
Old May 27, 2006 | 02:57 PM
Kevlo911's Avatar
Kevlo for President
Runs need to be done in 4th or 3rd. Check the ECU for codes, there is a sticky in the 4th gen forum that tells you how to check the codes.
Old May 28, 2006 | 09:21 AM
95BLKMAX's Avatar
Who the heck dynos on 2nd gear? If you have a 5spd you dyno on 4th gear, if auto you dyno on 3rd. Those are the gears that are closest to 1:1 ratio.
Dynoing on a lower gear will make it SEEM as if you have less WHP, so next time you go, dyno on the correct gear because you can't compare your #s against others, since no one dynos on 2nd gear.
Old May 28, 2006 | 10:46 AM
Kevlo911's Avatar
Kevlo for President
Actually, I thought dyno's in lower gears show HIGH TQ numbers?
Old May 28, 2006 | 10:54 AM
Zack342's Avatar
what's your altitude
Old May 28, 2006 | 05:17 PM
NmexMAX's Avatar
dot dot dot ...
And what's the correction factor?
Old May 28, 2006 | 10:39 PM
wunfstmax's Avatar
Did you go to mac? most dyno shops in colorado actually kinda know there stuff so im guessing they didnt do a second gear pull. I would have to say that it looks normal. The fact that you dyno'd about what a stock 5 spd would at this elevation, and with similar mods i ran a 15.6. I dont think any thing is wrong with your car.
Old May 30, 2006 | 03:59 PM
NAS's Avatar
NAS
mile high city of 5400 ft, Denver? I believe, correction factor was 1.24 Also with an I believe....sorry dont have the dyno sheet handy
Old Jun 3, 2006 | 06:09 PM
95BLKMAX's Avatar
indeed. I said that on lower gears WHP SEEMS lower, I said nothing about WTQ, which you are right, it will seem higher. At least that is what happened with me when I went to dyno a while ago and I did one 3rd gear run. But even with a lower gear, BOTH the WHP and WTQ are low.
Nas, any updates? any interesting finds?
Old Jun 4, 2006 | 07:21 AM
streetzlegend's Avatar
91 shell gas
Short Intake
Budget Y
OBX cat back
164.3 hp@5600
168.4 tq@4000
207.3 hp@5400
215.1 tq@3900
That does seem very low, i dynoed 50shot as well and i got 217whp and 240wtq. I don kno the bottle pressure either but i gained exacly 50hp. and gained 65lb tq. so i assume the pressure was perfect. I am automatic and was done in 3rd gear. CAI, 2.5 all the way back. udp. 93 oct citgo, 1 step colder ngk.
Old Jun 4, 2006 | 11:28 AM
NAS's Avatar
NAS
Hey all, I havnt had time to do anything to the car except a remote bottle opener but im still waiting on bottle heater and gauges... then back to a dyno, I do know the correction factor was 1.264 although I dont know what that correction factor is for, I am still looking into a safc, or just found this http://turboxs.com/more_info.php?ID=192
looks interesting but im not really sure what to do about the car running rich, I wonder if it runs rich in all gears or just the one that was dyno'd?
Old Jun 4, 2006 | 01:03 PM
at WOT, if ur car is running rich i think it will run rich at any gear. my a/f was also rich, specially during the nitrous pulls. i was between 11.5 and 12.08.
Apr 16, 2020 05:15 AM
Unclejunebug
Apr 2, 2016 05:42 AM
