Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
What gear in Auto for rolling dyno?
Old Jun 10, 2006 | 07:56 PM
killerVQ30DE's Avatar
When I dyno at my local place they always dyno auto's in 2nd, he insists that if its just left in Drive it will chop down a gear.. what is the norm for autos on a rolling dyno?
How much could I add to my record HP if I dyno in 2nd gear over the 3rd which has a closer to 1:1 ratio?
Old Jun 10, 2006 | 08:28 PM
SR20DEN's Avatar
VQ Wizard
The higher gears tend to read a little higher than the lower gears. This is because much of the energy is spent accelerating the wheels, flywheel, cranksahft, moving parts etc. . However on a load based dyno it almost doesn't show up at all. I have never seen anyone from NZ or AUS. post a dyno sheet that was done on an inertia based dyno (Dynojet).
Old Jun 10, 2006 | 10:43 PM
streetzlegend's Avatar
ur supposed to dyno auto in 3rd. leaving OD off. you accelerate and let the car shift its way to 3rd, and after the rpms pass 3k you floor it, the car will not downshift at that point. and thats when you record the dyno.
Old Jun 12, 2006 | 06:13 AM
NmexMAX's Avatar
dot dot dot ...
On a dynojet....
I've dynoed in 2nd and 3rd. Seems to me that the HP #'s are very close, but 3rd seems to give more tq.
Also, in 2nd the curve is much smoother, doesn't run the engine too hard, and for A33B's, gives more RPM to play with since it wont downshift over 30 mph. So tuning can begin from 3000+ (3250 ish)
Old Jun 12, 2006 | 02:33 PM
Heres my 2nd (auto) gear pull - (mevi not activating and KS found to be dead)
Re-dynoing on July 1st ..
So dyno'ing in 2nd doesn't show a measureable difference.. benefital even?
Old Jun 12, 2006 | 04:27 PM
NmexMAX's Avatar
dot dot dot ...
Dynoing w/a dead KS FTL...
Old Jun 12, 2006 | 05:50 PM
Not sure what your saying here? But I didn't intentionally run with a dead ks... I got the low 109kw power rating so I re-ran codes and got the 0304.. turns out my KS was loose, tightened up and now no codes.
I'm also waiting on Summit RPM switch so I can activate mevi again.
Old Jun 12, 2006 | 06:05 PM
NmexMAX's Avatar
dot dot dot ...
Hopefully you'll get some good # on the 1st.
Good Luck.
user 11122324
42
Jul 18, 2022 03:35 PM
BobTX10
Oct 7, 2015 08:43 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
