Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
new best 3.5 dyno...273hp, 249tq all motor
Old Jul 15, 2006 | 08:23 PM
96sleeper's Avatar
I went to dyno tonight for the heck of it. Since the last dyno I have installed a zeitronix wideband and tuned it on the street (which turned out identical when I datalogged on the dyno at 13:1) and I have also tweaked a few things in the intake tract. Still on the 02 maxima intake manifold.
Special thanks to SR20DEN for some pointers on what direction to head. Every time I dyno and see my torque below 4000rpm I wish I had done a full 3.5 swap, but I got too sweet of a deal on that engine to pass up so I went with it.
I absolutely can not wait until this fall when it cools down and I head back to the 1/4 mile track.
Old Jul 15, 2006 | 09:05 PM
Kevlo911's Avatar
Kevlo for President
WOW amazing numbers.
Old Jul 15, 2006 | 10:01 PM
AsthmaMax11's Avatar
Hey matt, is this a different dyno than last time?
Sick numbers man. I predict you'll be giving JIME a run for his money this year!!
Old Jul 15, 2006 | 11:33 PM
DandyMax's Avatar
3.5 in the works
Nice numbers. Looking forward to track results. I too cannot wait for the hot air to go away and cooler track days to come. Probably won't be anytime soon though. We're in the middle of a heat wave up here.
Old Jul 16, 2006 | 07:36 AM
SDot82's Avatar
I have the same heat wave coming through my area 100+ degrees.
Old Jul 16, 2006 | 08:05 AM
|Bijan|'s Avatar
UCF Lexus
jesus matt!
come to atl
Old Jul 16, 2006 | 09:01 AM
SR20DEN's Avatar
VQ Wizard
Got the run files?
And congrats. I am probably #2 in the hp department now. Oh well.
Old Jul 16, 2006 | 09:04 AM
SR20DEN's Avatar
VQ Wizard
Oh, and you can get that torque number back up by doing what I did with the ignition timing. That is if your ECU responds like mine did.
Old Jul 16, 2006 | 09:15 AM
gtr_rider's Avatar
192.168.1.1
NICE numbers..
95 maxima se's Avatar
Silver Tooth S2K 9k FTMFW
sick numbers!!!
Old Jul 16, 2006 | 09:48 AM
krismax's Avatar
Father of the 00 VI
those are def 12's kind of #'s
Old Jul 16, 2006 | 09:53 AM
DandyMax's Avatar
3.5 in the works
Run files for me too please!
DandyMax @ auracom . com (no spaces)
Old Jul 16, 2006 | 10:00 AM
Nismo3112's Avatar
Custom User Title
wooo!!!!! Sweet jesus
Old Jul 16, 2006 | 12:55 PM
96sleeper's Avatar
I should have the run files on Monday. I left and forgot a disk again as usual, but he promised to email them to me.
Old Jul 16, 2006 | 12:56 PM
96sleeper's Avatar
Originally Posted by SR20DEN
Got the run files?
As soon as you add cams, it will be over for everyone else.
Old Jul 16, 2006 | 04:32 PM
tavarish's Avatar
fwd gone rwd cr00
yeah, this engine without vtc's is a drag lower than 4500rpms. The big question I have for you is: do you have aftermarket rod bolts for the extended rev you have?
Old Jul 16, 2006 | 05:18 PM
96sleeper's Avatar
Stock rod bolts. I am only running to 7000 rpm. Technosquare flashes the 350z ecu's to 7100 rpm on stock rod bolts, so I concluded that I would be fine.
Old Jul 16, 2006 | 05:25 PM
Tatanko's Avatar
Bacon Lover
Good job on a new record
I only wish I had a 3.5 Oh well...
Old Jul 16, 2006 | 06:31 PM
GodFather's Avatar
Made in Taiwan
Hot dang! Nice hp+tq curvature you've got there. Man, so your power/rpm is like a 3 stage hauler. 200, 250, and 270. Nice...
Old Jul 16, 2006 | 08:18 PM
tavarish's Avatar
fwd gone rwd cr00
i'd go with arp rod bolts for added security. the 3.5 stock rod bolts aren't the best.
I can't wait to tune my car. it's running uber rich.
Old Jul 16, 2006 | 08:42 PM
nismology's Avatar
There's nothing wrong with the stock rod bolts unless you want to rev in the 7200-7500 RPM range.
Old Jul 17, 2006 | 05:47 AM
NmexMAX's Avatar
dot dot dot ...
Very nice #'s....
Sleeper FTW.
Also interested in the run files.
Old Jul 17, 2006 | 07:34 AM
ajcool2's Avatar
WOW. Congrats. I really need to step my game up.
Old Jul 17, 2006 | 08:27 AM
mforrest100's Avatar
I remember Matt said this before. Not really necessary to rev above 7000 which evident in his dyno graph seeing how the power starts to drop off after 6500 RPM's.
Old Jul 17, 2006 | 09:58 AM
virgilio7's Avatar
^ the power at 7000 is higher than it is at 5000. you land next gear higher in the powerband.
Old Jul 17, 2006 | 02:05 PM
NYPD-Arnold's Avatar
Z
Ehh...not quite correct. Instead of shifting into a weaker powerband, he'll be shifting into a higher RPM range and thus into a much stronger powerband.
Old Jul 18, 2006 | 06:18 AM
SR20DEN's Avatar
VQ Wizard
I am going to try, but I don't think I will be able to beat you now without them.
Old Jul 21, 2006 | 07:16 PM
A Canadian using the expression "heat wave"
A heat wave in Canada is like a cold winter breeze in Atlanta
Old Jul 21, 2006 | 08:07 PM
motocross416's Avatar
I'm at about the similar type of climate as dandymax, the heat waves we get are 90 degrees with 99 percent humidity, aka, severly down on power
Old Jul 21, 2006 | 08:40 PM
vsamoylov
not bad at all
Old Jul 22, 2006 | 02:56 PM
GoalieKeg's Avatar
You and me both.
Old Jul 22, 2006 | 04:38 PM
Hoooper
not so much. i was just up in ontario and the temp was 103 with a humidity around 70-90, i dont remember.
as for the OP, those are some pretty great numbers, i wish i was 30hp short
Old Jul 22, 2006 | 10:47 PM
liqidvenom's Avatar
brotherhood of tq
very nice numbers....
Old Jul 25, 2006 | 08:19 PM
E55AMG2's Avatar
Wat
Runfiles plz
Old Jul 26, 2006 | 06:23 AM
virgilio7's Avatar
what tweaks and mods you have? the list on your car domain only shows bolt ons like cutout headers and intake.
Old Jul 26, 2006 | 04:19 PM
csb's Avatar
csb
Hey...SR20DEN...I just tried to PM you, but it says you can't accept any more messages due to a full Inbox. So:
"Hello. I'm not quite finished with my 3.5 swap, however, I'd like to be prepared for the tuning process. The car SHOULD be up and running within 1.5 weeks. Which product should I purchase as a "piggyback"? I was considering the E-Manage Ultimate. I'll probably need your assistance when the time comes, OK? Thx."
Old Jul 26, 2006 | 04:40 PM
96sleeper's Avatar
page 3 of my cardomain shound have the latest list.
Old Jul 27, 2006 | 08:55 AM
SonicDust187's Avatar
Can you tell me what your idle is set to and does it have a loppy idle?
Old Jul 27, 2006 | 11:18 AM
DandyMax's Avatar
3.5 in the works
Thankyou! Why do people think Canada is all snow and ice? Nothing could be further from the truth.
Old Jul 30, 2006 | 04:29 PM
Hoooper
lol, def no ice there. and i was pretty far north
