Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
VQ30DE (mevi,pod,Y) 114kws : Dyno + video
Old Mar 5, 2007 | 03:49 PM
killerVQ30DE's Avatar
MEVI currently opens at 5100rpm What should I set it too based on the dyno? 5000rpm?
Blue = MEVI, Red/Green = mevi not activating runs
Video http://www.youtube.com/watch?v=QhzLHdds3nI
Old Mar 5, 2007 | 04:34 PM
speed racer's Avatar
So it looks like your making 153 whp. what's the torque in ft-lb. I woulds say your running a little rich after 80 km/h. It should be closer to 13
Old Mar 6, 2007 | 12:50 AM
TurTLe*'s Avatar
doesn't look like it took away from low and mid range the mevi that is. just a dip and all high end powa
Old Mar 6, 2007 | 10:26 AM
First dyno was with MEVI installed but not activating which might be why you can't see a potential difference in low/mid power.
I just upped the activation to 5300rpm and it does seem smoother engaging, I don't want to have dyno again to see if the dip is reduced but butt dyno says yes
Does anyone know how to convert my torque to ft-lbs?
Old Mar 6, 2007 | 12:15 PM
NmexMAX's Avatar
dot dot dot ...
I was thinking the same thing, until I myself. . .. . He's from NZ, he knows not of any USDM IM.
Old Mar 6, 2007 | 03:10 PM
Sort of do.. NZ Maximas have the same USDM IM.. its just the Imported JDM Cefiro's that all have MEVI.. JDM Cefiro 161kws > NZ Maxima 145kws
Old Mar 26, 2007 | 08:22 AM
hacim105's Avatar
based upon your dynos you should be activating the VI closer to 5450. The MEVI should open where those lines cross which is about 5450. So I'd move your activation up the at least 5400.
Old Mar 26, 2007 | 02:23 PM
jmeister's Avatar
Weird seperation between RPM points on that graph. 5300RPM might do it for you but like hacim said try 5400ish and see if you notice a difference. Def needs to be higher than what is was on dyno. That little dip around 4200-4400 is only going to be fixed by timing advance unfortunately. Why didn't they rev it out to 6500?
Old Mar 29, 2007 | 06:34 PM
I have set it to 5300rpm (approx, summit rpm hard to be exact)... if you listen to the video you to hear him bounce off the rev limiter so not sure why it comes up short
Old Apr 7, 2007 | 01:32 AM
Source's Avatar
nice video
the air/fuel ratio must be between 12,5 and 13
Old Apr 7, 2007 | 09:37 PM
Originally Posted by Source
nice video
You'd have to say that on stock ecu its sitting pretty close to optimal.. bout between 12 and 13.5 by my dodgy eyes. I have just cleaned my TB which seems to have made everything run more smoothly.. new exhaust tuesday so good excuse to dyno again Will do one pull at 5300rpm and 2nd at 5700rpm to where mevi opens best
Old May 1, 2007 | 01:53 PM
..bump ..bump
Based on my dyno above.. would a V-SAFC be worth doing or no?
Old May 1, 2007 | 07:12 PM
NmexMAX's Avatar
dot dot dot ...
I'd say yes, you could gain.
Old May 1, 2007 | 08:23 PM
95BLKMAX's Avatar
Do it, no question about it, there is more power to be had from a/f tuning here
Old May 2, 2007 | 11:15 AM
jmeister's Avatar
I don't think you're going to see much better gains out of an AFC. AFR isn't bad at all for the stock ECU, surprisingly. But hey VAFC2s can be had for under $200 shipped off ebay so if you want to mess with it go for it. But that means a dyno tune and more $
Old May 3, 2007 | 03:48 PM
Thats what I wanted to hear
Going to dyno tomorrow .. new exhaust.. and corrected MEVI openning.. 120kws? Previous dyno stock exhaust+Y & bad mevi openning = 114kw.
Will see if they can give me an increase estimate based on the AF ratios
Old May 3, 2007 | 03:55 PM
NmexMAX's Avatar
dot dot dot ...
I might dyno tomorrow too
How are you planning on conditioning your AFR?
Old May 3, 2007 | 05:43 PM
Do you mean how am I going to adjust Air Fuel ratios - eventually using Apexi S-AFC, V-AFC (which ever).. but tommorow I just want to get new dyno without the massive dip from VI activating and to see if new exhaust freed up some power. Then get them to tell me roughly how much they could gain me with an Apexi.
Local place has dyno day 1st sat of every month $US47 for mixture check and one power run pull.. going to ask if I can slip in a 2nd and try higher VI point too
Old May 3, 2007 | 09:55 PM
95BLKMAX's Avatar
well just for reference, on the 3.0 from tuning alone I went from 184WHP-187WTQ, to 191wph-195wtq. What those #s convert to in kws, I have no clue, lol.
Just for reference, my car ran a bit richer than yours. at 4500 (my richest point) I was at 11.9:1, the rest of the closed loop range (3k-redline) was mostly at 12.2:1.
Remember that not only does it help to make power by tuning the a/f, but it also makes the engine more responsive by doing so. I still love my SAFC.... but yea EVENTUALLY EU will replace it, lol
Old May 4, 2007 | 10:45 AM
NmexMAX's Avatar
dot dot dot ...
The reason a lot of these VQ's gain from tuning is the indirect timing affect.
These run rich, so that alone = gains, BUT, we also can add timing by taking out x% of fuel, effectively, adding timing to compound said gains
Old May 5, 2007 | 12:01 AM
Thanks dude good to know
litch
123
Jan 4, 2024 07:01 PM
AaronL
Aug 8, 2020 10:31 AM
jaydot901
Sep 29, 2015 01:18 PM
rbaker100
Sep 25, 2015 07:52 PM
